Engine Bay Thread
Old Oct 28, 2016 | 02:37 PM
  #436
g35g37fan's Avatar
g35g37fan
^use a trim pry tool on the apex of the Infiniti symbol (Fuji peak) and work your way around gently!
Just finished mine up, VHT Gold Flake Hight Temp Paint and Duplicolor High Temp clear! Taping is critical!
Old Oct 29, 2016 | 03:08 AM
  #437
jpowersjr2's Avatar
jpowersjr2
Great job! Turned out really nice.
Time for some gold dress up bolts to match now
Old Oct 29, 2016 | 07:37 AM
  #438
That makes sense at first, but the reality is that brightly colored dressup bolts look out of place, IMO. Usually its better to stick with black, or polished metallic.
Old Nov 28, 2016 | 10:27 PM
  #439
David.'s Avatar
David.
intake
Originally Posted by naka2510
quick picture, painted to match my blue slate
i just bought my Infiniti and it has the same intake on it as yours and I was just wondering what kind it is because it's not stock and i haven't seen one like that online
but some really good inspirations on here
Old Jan 7, 2017 | 05:08 PM
  #440
This picture was posted today in the Show off your Sedans thread, and I'm quoting it for member credit. Some guy in Japan named Robbie.
Originally Posted by aarr_ttyy
This bay is busy, no doubt, but it's undeniably pretty, too. Lots of great ideas here. Two things that jump out at me as something I want to explore:
1. Look at the CF wrap on the S-shaped plastic separators at the back of the bay, in front of the battery and the brakes. $10 for a 24"x12" sheet... easy enough to play with. Or you could ship those components off for hydro-dipping. That's got possibilities, too.
2. Look at the hose clamps on the intake couplers... they're beautiful. Did a little research, and found them here: ALUMINUM HOSE CLAMPS
...for only $7.50 a piece.
Old Jan 7, 2017 | 08:13 PM
  #441
ZahyMatar's Avatar
ZahyMatar
Those hose clamps are very nice, definitely going to replace the ones that came with my R2C intakes.
Old Jan 7, 2017 | 09:54 PM
  #442
Sometime before Spring, I plan to get two, in 2.75" black, to test the waters... so to speak. If it works out, I'll get the other four. Unless you scope it out first and confirm fitment, or shoot em down. Let me know, Z.
70mm converts to 2.75".
Old Jan 7, 2017 | 10:46 PM
  #443
G37xhibeet's Avatar
G37xhibeet
Yeah I came across those clamps. Considering them for when I have my intake powder coated and upgrade the couplers. There's also these if you wanna ball out
Prolock Hose Clamps .com - home
Old Jan 25, 2017 | 02:57 PM
  #444
louith's Avatar
louith
Added more CF pieces
Old Feb 1, 2017 | 04:29 PM
  #445
I just received two of these, to test the water. Ordered them in black, at 2.75" size. They're quite nice looking. Just as appealing as the photo.
However, these do *NOT* fit around the neck of the R2C filters. They're too big, and the width of the band is 3mm too big to fit inside the groove anyway. So they won't work here... unless I get out the razor blade and enlarge the grove on the neck. That's possible. I need to think about that. Still need to remove one of the mid-pipes and see if they work at the throttle bodies, but I suspect 2.75" is too big there, too, in which case I may try the 2.5".
Kind of annoying, but this **** happens. I talked to P2M just now, and they said they're getting a ton of confusing calls regarding diameter. Not unsurprising, considering the narrow tolerance in the design.
[edit]
I was wrong. 2.75" works just fine up at the throttle body.
Old Feb 1, 2017 | 06:30 PM
  #446
ZahyMatar's Avatar
ZahyMatar
[edit]
So 2.75" at the throttle bodies, and 2.5" for the filters? Those look great.
Old Feb 1, 2017 | 07:18 PM
  #447
Yes and no. 2.75" at the TB... yes.
And I'm guessing 2.5" at the neck for the R2C filters, but I won't know until I try it. And either way, you will have to get out the xacto-knife and widen the channel in the rubber by 2mm or 3mm.
And yes, I agree, they do look good. However, after I put my FSTB back on, they all but disappear and you have to really look around things in order to appreciate them.
You know what I'm thinking? Going black at the TB's, and getting the filter clamps in red. A little ring of red after the filters, in the shadows of the heat shield. It could look good, IDK What do you think, Z?
Old Feb 1, 2017 | 07:56 PM
  #448
Vizard_87's Avatar
Vizard_87
Where did you get the tank covered by the tommy kaira cover?
Old Feb 1, 2017 | 09:04 PM
  #449
ZahyMatar's Avatar
ZahyMatar
Why not orange/amber to keep it uniform with your engine cover? I think that would be a better match.
Old Feb 2, 2017 | 06:25 AM
  #450
No amber available.
Black, red, gold, blue, purple and pink. Seriously... pink
But I emailed P2M about amber anyway, just to see if that could happen.
