can someone explain this to me?
Old Feb 10, 2009 | 02:37 PM
AbadMiKE4's Avatar
AbadMiKE4
Dear Customer,
For the HyperFlux H1 LED bulbs, you just need to insert the red wire from the LED bulb to the stock socket and tap the black wire to the metal clip that used to hold the LED bulb on the base.
This special design ensures if there is a polar dismatch issue, you can simply flip the two wires around to correct the polarities.
__________________________________________________ _____
so i ordered h1 led bulbs for my FOGS and they came lookin like this ..
first when i tried plugging it in, i couldnt figure a way for the clip to hold the bulb steady, and secondly where to plug those wires? from what i understand from the email, is plug the red into the yellow wire? and what do i do with the black one?!?!?!?!? :confuse d2:
Old Feb 10, 2009 | 02:41 PM
ucla bruin's Avatar
ucla bruin
This is for your fog right?
Plug the red into the yellow and the black into the black. If that doesn't work, plug the black into the black when it is on the headlight metal part.
__________________
Old Feb 10, 2009 | 02:51 PM
AbadMiKE4's Avatar
AbadMiKE4
Im a bit confused to which black wire am i plugging the black one into? When i checked the housing, i only saw a yellow wire to plug into. The black wire is just a cover to some little red metal piece? and yes this is for my fogs
Old Feb 10, 2009 | 03:01 PM
ucla bruin's Avatar
ucla bruin
When you open your fog cover, there are 2 wires, a black one and a yellow one. The yellow one is plugged into the bulb, the black one is plugged into part of the metal housing.
__________________
Old Feb 10, 2009 | 03:06 PM
AbadMiKE4's Avatar
AbadMiKE4
i will check again, but i remember seeing the black one kind of welded into the metal housing.. where do i plug the black wire into? to i stick it in to the black rubber cover of that metal housing?
sorry- im a newb guys
Old Feb 10, 2009 | 03:18 PM
ucla bruin's Avatar
ucla bruin
That black wire is not welded. It can be unplugged, but first check if there's room for you to just stick the black wire from your new bulb into the black wire on the metal housing. Peel back the rubber cover so you can expose the plug more.
__________________
Victory
17
Oct 27, 2022 03:45 PM
User 122320
Buying & Leasing
Oct 15, 2015 01:47 PM
StAtiXz6
Intake and Exhaust
Sep 17, 2015 03:10 PM
Detailed Image
Car Care & Detailing
Sep 9, 2015 08:23 AM
cribbj
Sep 1, 2015 05:30 PM
