Auto Adjusting Windows
Old Jul 6, 2008 | 10:03 PM
EZDozzit's Avatar
EZDozzit
No Soliciting
Originally Posted by G37MA
To clear up the confusion at the time of the OP I did not do the window reset. In the manual it states that it is for the auto roll up feature and not for the auto adjusting feature. Since this post I have and it hasn't helped. I'm going to call service on monday for an apt. On a bright note the ECU reset helped tremendously. Car is much smoother in both engine and trans
What you described in your first post on this thread is exactly what happened to me when I installed my grounding kit. That's because I had to disconnect the battery. I fixed the problem by doing exactly what I posted above which is the Power Windows reset. The steps are also outlined in your owner's manual. Now if you tried this several times and it didn't work, then I agree, it should be taken to the dealer, which is what the manual also recommends.
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
arkyv714
Oct 4, 2015 03:44 PM
RexHavoc
Oct 2, 2015 11:47 AM
Bennyjoel
Sep 30, 2015 11:56 PM
