Notices
Just got my tint...a bunch of bubbles
Old 06-05-2008, 11:50 PM
hquach
hquach's Avatar
Quick question, when you guys got your tint, were there any bubbles? The guy that put it on said it will go away in a few days but theres A LOT! Theres about 10-15 on each of the driver and passenger windows. It has been a day, and the bubbles look a little smaller but there is a white dot in the center of every bubble. So does anyone know if these will go away clean? or should i bring it back to them?
Old 06-05-2008, 11:58 PM
Achilles
Achilles's Avatar
Wait a couple of hot days. They usually go away. If they don't, take it back and ask them to do it over, NOT just roll over them cause that doesn't work that great. Ask them to pull it off and to place it again.
They just might go away though.
Rule of thumb: Look through the tint, not at it. The hotter the days, the better.
Old 06-05-2008, 11:59 PM
B L U E S L A T E
B L U E S L A T E's Avatar
They'll go away in a day or two... depends on how hot the weather is.
Old 06-06-2008, 12:09 AM
DetroitG37Joe
DetroitG37Joe's Avatar
LEAVE IT IN THE SUN, that helps...
Old 06-06-2008, 12:14 AM
myk1013
myk1013's Avatar
yeah, they should go away in 3-4 days. But if they dont, get 'em replaced.
Old 06-06-2008, 12:33 AM
EZDozzit
No Soliciting
EZDozzit's Avatar
The tint bubbles on my IS350 took a whole month to go away. Tint shop said to be patient. Maybe the installer is just too lazy to get rid of them the manual way.
Old 06-06-2008, 03:00 AM
RhiNoKiLL
RhiNoKiLL's Avatar
Yeah u should havewatched him do it. White dots is little specs causing the film not to stick all the way to the glass. Wen I had mine done he did it outside. Only 3 small bubles and they don't go away if it has specs in them
Old 06-06-2008, 08:16 AM
IP37
IP37's Avatar
water bubbles will go away, air bubbles might not
Old 06-06-2008, 10:14 AM
NJKSC27
NJKSC27's Avatar
24 hours, if they are not gone, he did a bad job
Old 06-08-2008, 05:28 AM
Andyrox
Andyrox's Avatar
are they gone?
Old 06-08-2008, 06:39 AM
EZDozzit
No Soliciting
EZDozzit's Avatar
If you look at the center of the bubbles and see a little spec, those will definitely not go away. The others should. I had to take mine back on a car I had a few yrs back.
Old 06-09-2008, 12:05 AM
hquach
hquach's Avatar
most of them have flattened but there are still dots. it seems that they kind of go away when I scratch at them w/ my finger nail
i'm going to give it a couple more days and if they are not completely gone, I will bring it back to the tint shop
Old 06-10-2008, 05:31 AM
Staples
Staples's Avatar
I'm having the same issue using 3M 35% tint. I called yesterday and told them I wanted them to redo it and they said they would gladly, so we'll see what happens. It's not bad but there are a few small noticable bubbles on the passenger-side window.
Old 06-11-2008, 12:01 AM
D-Loc_-
D-Loc_-'s Avatar
i just got my windows done and the installer said bubbles are common for the first month or so.
Old 06-12-2008, 11:35 PM
Staples
Staples's Avatar
Well the company that installed my tint wanted to have nothing to do with my tint and they did the worst job I've ever seen. It really looked like an amateur's first time.
There are two types of bubbles; Air bubbles which is very normal for the first few days to a week, then there's dirt bubbles from not properly cleaning the window prior to installing the film. If you notice specs in the film then that's considered dirt under the film which WILL NOT come out ever. It will have to be pulled, cleaned, then reapplied.
The installer I went to did a terrible job and there were tons of dirt bubbles in the film and they were giving me the runaround and weren't taking the blame for their mistakes. So now I'm out $280 and I'll be out another $170 to get it installed right.
By the way, don't use 3M film because it contains a yellow adhesive that will make the tint turn purple within a few years.
Luminar is a better quality and is backed with a lifetime warranty, unlike 3M which is only backed 3 years.
Quick Reply: Just got my tint...a bunch of bubbles
