Door Panel Removal
Old May 13, 2008 | 10:50 PM
gassedracing's Avatar
gassedracing
Door Panel Removal
Searched and can't seem to find anything. I am hoping someone has some detailed instructions on how to safely remove the door panel and spare the annoying clips that often accompany a door panel.
I have rattle in the passenger side door that the stealer just can't seem to resolve, so I am going to take matters into my own hands...and probably add some weight with some sound deadener while I am at it.
Thanks!
Old May 14, 2008 | 12:24 AM
TXG37S's Avatar
TXG37S
The instructions and diagram are in the int.pdf section (page INT-11) of the Service Manual. You'll find the link in the FAQ & DIY forum.
  1. Fully open door window.
  2. Remove inside handel escutcheon with remover tool.
  3. Remove screw located on the back side of the inside handle escutcheon
  4. Remove armrest cap with remover tool.
  5. Remove screws located on the back side of the power window finisher.
  6. Remove step lamp.
  7. Insert a remover tool into clips on door finisher and dis-engage clips.
  8. Pull up door finisher and pull out toward vehicle inside.
    • Disconnect seat memory switch connector.
    • Disconnect tweeter connector.
    • Disconnect door squaker connector
  9. Disconnect lock **** cable and inside handle cable from door inside handle assembly.
  10. Disconnect power window switch connector and mirror control switch connector.
  11. Remove door finisher.
  12. Remove the following parts after removing door finisher.
Old May 27, 2008 | 10:05 AM
rcharles's Avatar
rcharles
Did you find your rattle. i have one in my passenger door also.
Old May 27, 2008 | 12:15 PM
Kuz's Avatar
Kuz
Its the insulation which the speaker shakes. Thats the noise you are hearing. My dealership "fixed" it, but I still hear it sometimes. I'm thinking af looking behind there myself and do a more thorough job of fixing the rattle.
andrewk523
Nov 11, 2015 05:49 PM
Murkr
Sep 28, 2015 10:45 AM
r0cketm0nkey
Sep 27, 2015 01:34 PM
JerseyG
Sep 23, 2015 02:20 AM
