Fog lights too hot??
Old Mar 6, 2008 | 11:20 PM
G-Spot37s's Avatar
G-Spot37s
Question Fog lights too hot??
Yesterday I installed the MTEC 4350K H1 fog lights. After having the lights on for a few minutes the headlights got hot! Very hot, like hot beyond belief. Do all fogs get really hot, and do the stock fogs get really hot too? Has anyone noticed the same thing?
Old Mar 7, 2008 | 01:10 AM
Twerkinpnoi's Avatar
Twerkinpnoi
you installed HIDs in ur fogs?
Old Mar 7, 2008 | 08:59 AM
G-Spot37s's Avatar
G-Spot37s
The bulbs are similar to H.I.D., but they are not H.I.D. Bulbs. They are considered Racing Halogen Bulbs that are an extreme white color. Also are a great color match to our stock 4300k stock headlights.
Old Mar 7, 2008 | 09:01 AM
todd92's Avatar
todd92
Higher wattage than stock then? If so, that's why.
Old Mar 7, 2008 | 10:59 AM
G-Spot37s's Avatar
G-Spot37s
The bulbs are 55 watt that produce 100 and they are also 12volt. Is that the same as stock? If so, have you ever noticed that your stock fogs make the headlight housing extremely hot?
Old Mar 7, 2008 | 03:37 PM
todd92's Avatar
todd92
It's either 55 or 100, can't be both. Not sure what stock is, but 55 is typical for headlights, 100 would get pretty hot.
Old Mar 7, 2008 | 03:41 PM
G-Spot37s's Avatar
G-Spot37s
The bulbs use 55 watts, abd put out 100. The bulbs are MTEC 2X, but MTEC also offers 4X that use 100 watts and prouce 150 watts.
Old Mar 7, 2008 | 04:27 PM
JMP0323's Avatar
JMP0323
yes, when i installed mine i had the stock fogs on for bout 45 sec and then removed them and they were HOT
Old Mar 7, 2008 | 07:25 PM
G-Spot37s's Avatar
G-Spot37s
Yeah, the bulbs get hot quickly, but does the actual headlight housing get hot as well? Mine is very hot to the touch after being on for a few minutes.
Old Mar 7, 2008 | 09:08 PM
art in motion's Avatar
art in motion
for what ive experience with MTEC it did the same for me... they are great looking bulbs but do not last long... had them on 2 previous cars both blew before 6months
Old Mar 8, 2008 | 12:55 AM
G-Spot37s's Avatar
G-Spot37s
Did you handle the bulbs with your hands? I dont see why they wont last at least 6 months. And after they blew, what bulbs did you end up putting in?
Old Mar 8, 2008 | 07:48 AM
art in motion
I always wore gloves when handling any bulbs going into headlights... ive ran silverstars for the most part... now running piaa
Old Mar 8, 2008 | 12:27 PM
G-Spot37s's Avatar
G-Spot37s
What color temperature are you running with the Piaa, and how much did they set you back?
Old Mar 8, 2008 | 02:25 PM
solopresident's Avatar
solopresident
if they run very hot with no place for the heat to go it will burn them out faster.
Old Mar 8, 2008 | 09:34 PM
art in motion
check out ebay for whichever output you want
im running 4100k
