Driver door problem?
Asked a dealer about the problem, his response was that the passenger door requires more effort to close due to the added safety incase of the collission. Basically he talks nonsense.
I will get the car to the Infiniti service next week. Someone said here "Are you that weak that you can't put extra strength in closing the door"
1. Long term damage very possible.
2. It gets very uncomfortable, especially closing from the inside, it is like you closing a 60s car door. After driving G35 for 3 years, I got used to closing it easily.
I gave to my brother to test drive the car, and since before he was in the passenger seat, he noticed the difference in closing the door immediately. He said, "It feels like the belt stuck or something?!"
Great NorCal Dealer
All - as an FYI, Infiniti of Marin has been amazing in their attempts to resolve this issue for me! I will keep you apprised of their findings, but they are bending over backward and have not yet said, "They cannot fix," or any other indication that I'm crazy.
If you are in the NorCal area, I highly sugest you use them...
Lee
Lee
Dropped of a car today, service dept. mentioned that it happened because of tinting, when company tints the windows for you, because of frameless windows, this problem can happen.
I told the service dept. that this problem was on the same day of the purchase but I was just told by the dealer that it is natural. At first I thought fine but later noticed that the door hits the top of the door frame when closing.
They will tell me later on today if the warranty will cover it or not. They blame the tinting company but I know for sure that was before tinting was done.
Word of warning to all the buyers, check your car thoroughly before leaving the dealership after the purchase.
It is not that big of a deal, all you need to do is put a LITTLE more effort when closing the door (You dont have to slam it). It does not take that much more strength to close the door. If you are that concerned or WEAK, you should go to the gym and lift some weights. Hahaha
i have noticed once in a while that closing the driver's side door requires more effort than i originally expected. but since i've never sat in the passenger seat, i don't have anything to compare to. i will check this tonight and get back to you guys.
I highly recommend you bring your car in for this adjustment if you have this issue - you will absolutely notice that the lines on the car are MUCH cleaner once the driver side front fender and driver door are adjusted to fit properly!!!!
And, for the record, don't think it escapes me that the vehicle left the factory with misaligned body panels. Didn't make me happy or, at all comfortable to have my 2 mos old car in the body shop.
L
L
KZK
Canada
09-02-2015 05:30 AM
