Removing Tail Lights! Frustrated!
Old Mar 1, 2008 | 11:44 AM
kmare's Avatar
kmare
How did the signal replacement go?
Old Mar 1, 2008 | 01:47 PM
raptorius's Avatar
raptorius
very nice. Love what you license plate says, ahah.
Old Mar 1, 2008 | 06:12 PM
TerribleONE453's Avatar
TerribleONE453
Looks nice... i wanna do mine
Old Mar 1, 2008 | 06:56 PM
UNV-IT46's Avatar
UNV-IT46
so you didnt replace any of the clips or items that were taped on with new ones?
Old Mar 2, 2008 | 10:47 PM
delfin2003's Avatar
delfin2003
Ok guys, finally, after spending $$$ for lots of bulbs and testing, got my lights done!!! So for reverse lights, use these, 194 168 W5W 2825 SMT Tower III from autolumination.com Here is the link:
http://autolumination.com/194.htm
For signal bulbs, user 5 watt led bulbs, others are too dim!Got them from eautoworks.com, model #113619 - SPL3091W. Here is the link. http://www.eautoworks.com/html/produ....cfm?id=113619. Also buy the resistors from there as well, 6ohm 50 watt resistors will eliminate fast signaling problem once the leds are installed. Make sure to get 3157, 3156 will NOT work. On 3157 you will have to bend clips just slightly to make contact. I also taped led to the bulb socket to make sure it does not fall out in case of a vibration.
Old Mar 2, 2008 | 10:56 PM
soonerlm's Avatar
soonerlm
video or pics!
Old Mar 3, 2008 | 03:04 AM
TerribleONE453
What color? White im guessing..?
Old Mar 3, 2008 | 03:12 AM
TerribleONE453
yea i wanna see pics of the signal bulbs... already ordered a set for the reverse lights
Old Mar 3, 2008 | 06:39 AM
myk1013's Avatar
myk1013
Wow, first time I've seen this. You have to remove the taillights to change bulbs?! Whatever happened to taking out a piece of plastic panelling from inside the trunk and reaching from there.
Old Mar 3, 2008 | 11:13 AM
delfin2003's Avatar
delfin2003
yeah, white color for both reverse and tail. I'll post some pics tonight or maybe a video
Old Mar 3, 2008 | 11:23 AM
delfin2003's Avatar
delfin2003
btw, my next project will be splicing a video bypass module into stock RGB connector, so you can watch video while driving. And since its RGB, it will not affect your NAV system. As soon as I'll do that, I'll post it somewhere otside the this forum, since this forum does not allow that!
Old Mar 3, 2008 | 12:38 PM
TerribleONE453
PM me when you figure that out!!!!
Old Mar 3, 2008 | 01:24 PM
shumby's Avatar
shumby
PM me too I know how to do the AUX and nav hack but if the RGB will not affect the speed sensor let me know.
Old Mar 3, 2008 | 02:20 PM
  #29
delfin2003's Avatar
delfin2003
Old Mar 3, 2008 | 08:23 PM
  #30
delfin2003's Avatar
delfin2003
Pics!!
Attached Thumbnails Removing Tail Lights! Frustrated!-img_1569.jpg   Removing Tail Lights! Frustrated!-img_1571.jpg
