Help Bose replacement help
Old Oct 7, 2023 | 09:34 AM
rtg21's Avatar
rtg21
Exclamation Bose replacement help
Hello, I'm trying to replace the stock bose amp. I've have never wired a 4 channel amp before. I want to use the factory wires that runs to the speakers, I don't want to run any speaker wires to them. I'm a bit confused on the connections. I'm going to use the Bose harnesses in the trunk to connect the aftermarket amp. Are these the correct connections I need to make? Do I splice into the harness wires or do I completely sever the mentioned connections from the bose amp? Diagram attached.
Old Oct 7, 2023 | 10:58 PM
beefychicken's Avatar
beefychicken
Try this cmapny, they have adapter cables for different configurations such as replacing an amp, adding a sub, etc.
HOME | OWC Upgrades (owc-upgrades.com)
Old Oct 8, 2023 | 09:56 AM
socketz67's Avatar
socketz67
Community Builder
Adding @OWC to the thread.
OWC has described several options here: https://www.myg37.com/forums/audio-v...ug-n-play.html
I have a question about the following setup as I have always wanted to replace the front 10" drivers and tweeters, then also add a small amp, but I could never figure out if doing so would delete the "Sound Stage" function since I'm not sure if that signal processing occurs in the head unit, or Bose amp.
Old Oct 10, 2023 | 08:49 PM
OWC's Avatar
OWC
Hello. If you'd like to replace the stock Bose amp, then you can save a lot of time, confusion, and damage to the factory wiring by using an OWC harness adapter.
The adapter to replace the factory amp simply takes the place of the stock amp. It then provides you with all 4 Preamp Signals, a Remote Turn-On Connection, and Speaker Wiring (to utilize the factory wiring already in your car). That's basically everything you need to easily & professionally connect your new amplifier upgrade, except the main 12V power & ground wire required for your new amp. You'll still need to supply that separately, which is fairly easy to do.
If that sounds interesting, you can check them out at the links below.
The More Budget Friendly kits for the G37 are here: G35 / G37 (2007-2013): Audio Interface Harness Adapters, RED LINE | OWC Upgrades (owc-upgrades.com)
And the Super High-Quality kits are here: G35 / G37 (2007-2013): Audio Interface Harness Adapters, PLATINUM SERIES | OWC Upgrades (owc-upgrades.com)
Hope that helps. Feel free to hit me with any questions you may have.
OWC
Old Oct 10, 2023 | 09:28 PM
OWC's Avatar
OWC
Good question.
The interface to add an amplifier to drive the front 10's and tweeters+mids is designed to retain all the audio setting capabilities of your car. The "Sound Stage" or "Driver's Audio Stage" function is primarily processed in the head unit, but the Bose amp does play its' part in processing the center channel. With the setup you mentioned, the Bose amp continues to power center and all the remaining speakers/sub. So, you'd simply be upgrading the front door speakers and giving them some extra clean power with no loss in functionality. It's an easy win.
Old Oct 11, 2023 | 07:20 PM
socketz67's Avatar
socketz67
Community Builder
Originally Posted by OWC
Good question.
Thanks for the clarification @OWC . Truth be known, I have an amp/sub and Epicenter today and need to leave the Sound Stage off for those to work properly. However, if I ever sold the car, I wanted to make sure this OEM feature is enabled.
Which OWC harness would I buy to power the set of front (3) door speakers with a two channel amp?
Old Oct 11, 2023 | 07:21 PM
socketz67's Avatar
socketz67
Community Builder
Good question.
Thanks for the clarification @OWC . Truth be known, I have an amp/sub and Epicenter today and need to leave the Sound Stage off most of the time so that those work properly. However, if I ever sold the car, I wanted to make sure this OEM feature can be enabled as it was an important feature when the car was new: https://www.stereophile.com/news/071...iti/index.html
Old Oct 12, 2023 | 12:22 PM
OWC's Avatar
OWC
Sure thing @socketz67 . I can definitely understand the importance of maintaining OEM features like that.
All the harnesses are named according to the upgrade you'd like to do. So, in your case, you'd purchase the kit to "Amp the Front Speakers".
That would give you instant connections to the front door speakers, a remote turn-on wire, and a 2-channel RCA cable connection all built into one interface. It makes for a really clean setup.
And if you ever decided to sell your car or audio equipment, all you have to do is unplug it.
What sub/amp combo are you running in your car now?
Hdinh94092
Dec 10, 2016 02:56 PM
Reload
Nov 11, 2016 09:11 PM
greco65
Nov 2, 2015 09:46 AM
DHS803
Oct 28, 2013 05:59 PM
arbelaezr
Oct 9, 2008 01:52 PM
