Help Cruise control dial not working
Old Aug 15, 2023 | 06:55 PM
awesomeEL218's Avatar
awesomeEL218
Hello, I drive a 2011 G37x sedan and the cruise control dial to set/change cruise stopped working all together. The on off button still works and I’m assuming so does the cancel button (I haven’t been able to set cruise to actually see.) I’ve read some of the other threads regarding clock spring failure but in my case I just haven’t had symptoms to make me think that’s the case. Is this the start of a clock spring failure or just something simpler? All other steering wheel controls and systems work perfectly.
Old Aug 15, 2023 | 07:47 PM
ILM-NC G37S's Avatar
ILM-NC G37S
More than likely the switch has gone bad. Rare, but not unheard of. It is not the clock spring as the other buttons work as intended. Does the horn work and do the steering wheel buttons light up at night?
Old Aug 15, 2023 | 07:50 PM
awesomeEL218
Yes the horn works just fine and all buttons light up at night.
Old Aug 15, 2023 | 07:59 PM
ILM-NC G37S
Then it is not the clock spring. You will need to replace the steering wheel switches.
Best advice: scour eBay or any local pull-a-part junkyards for a used replacement. Keep in mind that on eBay at least, it may be cheaper to buy a used steering wheel WITH the switches still attached as many sellers do not separate the two.
jose16388
Oct 2, 2024 10:29 PM
Arctic922
May 13, 2023 11:37 AM
saywat?
Feb 15, 2019 01:38 PM
frank.leon002
General Tech Questions
13
Dec 7, 2012 06:34 AM
Dieseldoug22
Jul 2, 2009 02:32 PM
