Modding the OEM Navigation Head Unit / Gaining GT-R MFD & Other Functions
Old Feb 10, 2024 | 01:24 PM
  #121
RobC7's Avatar
RobC7
How is testing coming along?
Old Feb 10, 2024 | 07:20 PM
  #122
SonicVQ's Avatar
SonicVQ
This should give you tire pressures:
Old Feb 10, 2024 | 07:43 PM
  #123
prodrive11's Avatar
prodrive11
https://youtu.be/hVikE-EOncg
Hey, that's exactly not the one i want, please see my last line:
Originally Posted by prodrive11
Also hoping with above TPMS setting (TPMS information = 2 (D52E type)), i'll see GT-R specific screen, but it doesn't show in INFO. I know GT-R shows it regardless of speed. So i'm missing something here for sure.
Old Mar 29, 2024 | 10:22 AM
  #124
pburger's Avatar
pburger
2013 G-37 Vert w/Nav
I think I'm going to try and connect to the AV unit to get into console mode. I'll have to find a free weekend, because I'll have to pull the dash apart. Before I do that, I'm hoping to get some help with the following questions:
1. Does anyone have a source for the pins for the 32-pin connector?
If my research is correct, the 32-pin connector is a Sumitomo TH32FW-NH (6098-5287), and the pins are either 8240-0367 or 8240-0369, depending on the wire size, but I can't find a source for these.
[EDIT - I believe the proper part number for the pins is 8240-0253, I was able to get some from AliExpress. I hope to try to connect soon.]
2. I plan to bring out the TX, RX, and B2 from that connector. What should I use for ground or common? Should I pick up a SHIELD connection on that 32-pin connector? or just use the case as ground?
Last edited by pburger; Apr 11, 2024 at 04:37 PM. Reason: correcting incorrect information
Old Apr 11, 2024 | 01:15 PM
  #125
SupraOfDoom's Avatar
SupraOfDoom
I assume he's gotten busy with life since he went MIA. I will patiently wait.
Old Apr 12, 2024 | 11:17 AM
  #126
MotorvateDIY's Avatar
MotorvateDIY
Sorry for the delay in replying, somehow I missed this post until SupraofDoom posted below.
Anyways, I've been testing it in my G37 every time I drive it and the gauges are working very well!
I did a minor firmware update in Jan to use hardware timers for more consistent CAN frame message transmission.
No noticeable difference, but the code is cleaner.
Now that the warmer weather is here, I'll be doing local testing on 4-5 G37 to make sure it works on all the different versions.
(Auto RWD/AWD, 6MT RWD, and Technology package with ICC)
Old Apr 12, 2024 | 11:20 AM
  #127
MotorvateDIY
Thanks for this post... Somehow I missed RobC7's comment and this post pointed that out!
Old Apr 13, 2024 | 11:23 PM
  #128
Bill238's Avatar
Bill238
Any idea what the reserve pins are for?
Old Apr 14, 2024 | 09:08 AM
  #129
MotorvateDIY
I can't find GT-R splash screen, tried different combinations with:
no luck. Do you know what config brings GT-R splashscreen ?
Here are the "sys" commands to change the startup / splash screen:
Code:
Infiniti: sys 2 9 1 9 0
Nissan: sys 2 9 1 9 1
GTR: sys 2 9 1 9 2
Then type
Code:
pld 3
to copy the startup image from the drive to flash.
Have fun!
Old Apr 14, 2024 | 09:13 AM
  #130
prodrive11's Avatar
prodrive11
Code:
GTR: sys 2 9 1 9 2
Then type
Code:
pld 3
Have fun!
Yeah, found that. Now I'm looking for proper GT-R TPMS screen. Had little time on that, was focusing on building the car...
Old Apr 14, 2024 | 09:35 AM
  #131
MotorvateDIY
I got my connectors at the scrap yard, when I got the nav unit.
As for the grounds, I used the ground pins on the 32 pin connector. I suspect you can also use the case as a ground, just make sure to test for conductivity between your ground and the case.
Sometimes, there are multiple and independent grounds.
Old Apr 14, 2024 | 09:38 AM
  #132
MotorvateDIY
No idea, all I know is that I didn't need/use them.
Old Apr 16, 2024 | 12:30 PM
  #133
Bill238's Avatar
Bill238
Any updates on the USB to AV terminal boards?
Old Apr 16, 2024 | 04:14 PM
  #134
MotorvateDIY
Not including you, there was only one other person who was interested, so none were made.
However, the USB debug mode used to enable the G37 Tire pressure on the nav unit, gives the same console access.
Old Apr 16, 2024 | 05:23 PM
  #135
Bill238's Avatar
Bill238
No worries! I tried the USB route on a a later Maxima unit with no luck. I think the debug is the same physically, but my soldering skills aren’t the greatest. On the pictures of your board, there are 4 lines coming from the 32 pin connector. I got IT-PC, PC-IT, and the ground for TB2. What was the fourth wire? I can’t really tell from the picture.
