Factory Bose Head Unit with Helix DSP: low inputs or high inputs??
Old May 12, 2021 | 01:48 PM
Pappa14's Avatar
Pappa14
Hello,
So I have a 2013 g37 with factory Bose (No Nav). I have taken all the stock audio out except for the head unit and added all aftermarket equipment including a Helix .3 DSP. I have read in several forums that the signal coming from the head unit is a full clean signal and that it is low level output. So my question is do I just add rca connectors to the front left and the front right output from the head unit and connect to the low level input or connect to the high level input of the DSP? Would I benefit from going one way or the other? Any help on this would be greatly appreciated! Thank You
Old May 12, 2021 | 04:04 PM
13_SkylineSedan's Avatar
13_SkylineSedan
Yes, the Bose head unit outputs are line level so those would be the inputs to use on your Helix box.
Pappa14
Mar 16, 2021 11:43 AM
Aslmx
Feb 7, 2021 07:29 PM
voha123
Nov 29, 2016 08:00 PM
_infiniti_don
Sep 18, 2014 08:53 PM
