Need new steering wheel lock module
Old Feb 7, 2020 | 05:06 PM
Joe27's Avatar
Joe27
Anyone knows the parts number for an 2013 Infiniti g37 my steering won't unlock so my car won't start
Old Feb 7, 2020 | 06:39 PM
13_SkylineSedan's Avatar
13_SkylineSedan
Hey Joe,
This is the 4th thread you've started over the past couple years which contains "car won't start"? Sorry you're having so much trouble with your G.
What makes you think the steering wheel lock is what is preventing the car from starting this time? As far as I know, the condition of the steering wheel lock is not a factor in the starter circuit working ... I could be wrong. The things that I do know need to be working are the shift position sensor and the brake pedal switches.
Old Feb 7, 2020 | 07:00 PM
ILM-NC G37S's Avatar
ILM-NC G37S
This is a well known and documented issue on certain 2009-2011/12 Nissan AND Infiniti models. If the steering wheel lock does not unlock the steering wheel, the car WILL NOT START. The ECM receives a signal from the ESCL module which, along with IVIS/NATS, judges start/no start conditions.
That said, this system was done away with by Nissan in 2013+ models. Being OP has a 2013 it is hard to say if this is the issue or not.
FOR REFERENCE:
The ESCL (Electronic Steering Column Lock) module is p/n: 48600-1NC1A and the cheapest is $710 from discountinfinitiparts.com. This part DOES NOT APPLY TO 2012+ models.
Old Feb 7, 2020 | 07:06 PM
Joe27's Avatar
Joe27
Originally Posted by 13_SkylineSedan
Hey Joe,
I was told by an mechanic that it could be my steering wheel lock module so I looked on youtube and Google to find out I seen an couple videos showing people with the same problem as my car it doesn't want start it just flashes my key light on the dashboard but it let's me open my doors and turn on the radio but won't start so I was trying figure out what my part number would be
Old Feb 7, 2020 | 07:55 PM
ILM-NC G37S
With the button in ACC or ON, are you able to turn the steering wheel?
If no, the ESCL is stuck. If yes, then you have a different issue.
Old Feb 7, 2020 | 08:42 PM
Joe27's Avatar
Joe27
It turns so it must be something else you have any idea what it could be ?
TVPostSound
TSB - Technical Bulletins
Dec 31, 2020 02:16 PM
blkceaser
Feb 9, 2019 06:14 PM
G37slove100
Oct 18, 2013 02:37 PM
