Help Nav buttons not working
Old Oct 14, 2019 | 04:50 PM
Knightjs's Avatar
Knightjs
2011 G37S. Recently noticed I have some buttons not working. Anything dealing with the nav is out, and the settings button as well. Radio and a/c are fine. Can't check the diagnostic because the settings button is needed. Do I just need to replace the button assembly? It's only $10-$20 from LKQ on eBay. Or perhaps the vents with the button assembly as a whole would be easier to swap, less disassembly? Mainly I need to know if either will correct my problem. I don't use the nav but I do like to access my maintenance reminders and fuel mileage settings.
Old Oct 14, 2019 | 05:27 PM
ILM-NC G37S's Avatar
ILM-NC G37S
You could try checking the ribbon cable that connects the NAV switch assembly to the HVAC/Radio switch panel. Could be as simple as a loose connection.
With anything there is no 100% guarantee that replacing the switch assembly will resolve your issue, though more than likely it will.
Old Oct 15, 2019 | 02:02 PM
Surfnazi's Avatar
Surfnazi
Sounds like your control board is going bad
Old Oct 15, 2019 | 05:49 PM
Knightjs's Avatar
Knightjs
Ordered one from LKQ on eBay. Got a 90 day warranty. I'll find out this weekend.
Old Oct 19, 2019 | 11:15 AM
Knightjs's Avatar
Knightjs
Ordered the whole piece. Vents, trim and the buttons. Thought it would save a few steps. But my original trim and vents looked alot better than the replacement so I kept them. Problem is solved. Everything working again.
Old Oct 19, 2019 | 12:16 PM
ILM-NC G37S
Glad you got it sorted and working again. Thanks for the update!
audiotechnica
Sep 30, 2021 08:10 AM
Fezzik
Aug 7, 2010 11:45 AM
pdarby
Jul 25, 2008 06:32 PM
shumby
Nov 11, 2007 01:34 AM
