Navigation panel replacement...
Old May 20, 2019 | 10:04 PM
carl292's Avatar
carl292
So my wifes bottom left buttons just stopped working. The am/fm and the disc aux do nothing , so i’m thinking the board possibly. Luckily, it stays in fm mode but she can’t pair her iphone music because she needs to switch to aux i believe she said.
Anyone dealt with this issue or have a solution? Thanks
Old May 21, 2019 | 05:26 PM
G37sPhoton's Avatar
G37sPhoton
Hey man....same here with my 11...just stopped functioning suddenly..though i did take off the climate control for some console work and thought i messed it up etc...but it worked after and then just stopped responding...someone mentioned the diagnostics menu, but no luck there...check fuses, but nothing came up specifically for these buttons and all seemed in order, so only option im thinking at this point is to purchase a used one on bay...ranging from 45-60...let me know if you find out different solutions as I rarely ever used them before, but now wanted to stream Pandora after changing phone providers and now it goes out on me...figures...
Old May 22, 2019 | 07:51 AM
carl292's Avatar
carl292
Thanks for the info! Have you seen any write up to removed and replace? I searched and found everything but that
Old May 22, 2019 | 01:42 PM
teahead's Avatar
teahead
worth a shot, but disconnect battery, wait 30 minutes, re-connect.
Old May 25, 2019 | 10:40 AM
G37sPhoton's Avatar
G37sPhoton
Re instructions , its same as the panel removal..2 screws for center panel and pull it back but don't disconnect wires...place a cloth on lower console andnket it rest there...2 screws for upper console and pull back...disconnect the one wire...connect the new one and replace in reverse and voila ...should be good to go...not a bad idea to disconnect negative though with any electrical connections....
slupe
G37 Convertible
Oct 28, 2018 11:32 AM
Tunerz_Store
Engine/Intake/Exhaust
115
Jul 16, 2017 10:20 PM
chris01919
Dec 10, 2014 01:06 PM
warpeacelove
Jul 24, 2013 08:29 PM
madmach
Jul 11, 2010 09:41 PM
