AM/FM Static on a convertible
Old Mar 6, 2019 | 06:18 PM
Alex Algieri's Avatar
Alex Algieri
I have a 09 G37 convertible and the radio (AM/FM band) is all static. I press the seek button and it never stops. If I manually put it on a station and it work (kinda). What can I do? Can I put on an aftermarket antenna?
Old Mar 6, 2019 | 06:40 PM
stealthee's Avatar
stealthee
Do you have any aftermarket LED or HID lighting? They put off a radio signal that can interfere with stations. You may also need to look into seeing if the antenna is actually hooked up at the headunit and at the antenna itself.
Old Mar 6, 2019 | 06:45 PM
Alex Algieri
The car is 100% stock. The radio works a little. The AM does not catch any stations. FM only catches a few. I also live in Miami and the signals are strong. I also want to get rid of the long antenna, any ideas?
Old Mar 7, 2019 | 06:22 PM
Alex Algieri
Can anyone help me out?
Old Mar 8, 2019 | 11:28 AM
ILM-NC G37S's Avatar
ILM-NC G37S
The symptoms you describe can either be a bad antenna/ amplifier or a bad connection. The first thing you could do is check all of the antenna connections both at the headunit and at the antenna base.
(2010 'Vert, 2009 should be similar):
As for aftermarket antennas, I am sure there are options out there. Perhaps someone can offer more information on them. I never use AM/FM, or XM for that matter, so I just do not know. Just remember if you remove the antenna you will have a hole in the decklid:
Hope some of this helps.
Alex
Old Mar 8, 2019 | 12:48 PM
Alex Algieri
The symptoms you describe can either be a bad antenna/ amplifier or a bad connection. The first thing you could do is check all of the antenna connections both at the head unit and at the antenna base.
As for aftermarket antennas, I am sure there are options out there. Perhaps someone can offer more information on them. I never use AM/FM or XM for that matter, so I just do not know. Just remember if you remove the antenna you will have a hole in the decklid:
Alex
Thank you for the reply... I checked all the connectors. It's only a problem with the AM/FM stations. Sometimes it works and other time it just rolls over and over. Can the AM/FM antenna just go bad? If so what parts do I need to change?
Old Mar 8, 2019 | 01:16 PM
ILM-NC G37S
It is rare but possible for the antenna amp to fail. The amp is located in the antenna base. Judging from the FSM (again, for 2010 'vert), the antenna has 2 wires: a signal wire and a 12V power feed. You could make sure the amp is getting power. If everything is checking out good, then you might have a bad antenna.
There are a few on eBay, used, for around $40 and up. I know you were interested in aftermarket, but as a last resort one of those may be a option.
Wish I could be of more help....
Old Mar 8, 2019 | 01:24 PM
teahead's Avatar
teahead
Do you have the factory chrome rear spoiler or a painted one?
If the latter, possible PO or dealer installed it and forgot to hookup the am/fm antenna.
There's another thread on that very issue in the Convertible section.
Old Mar 8, 2019 | 02:54 PM
Alex Algieri
Thank you... The car has the chrome trim.
Old Mar 8, 2019 | 03:16 PM
Alex Algieri
Does anyone have a part number for the antenna amp? Or any other known working aftermarket antenna?
Old Mar 8, 2019 | 07:26 PM
ILM-NC G37S
Alex, from what I can tell, the AM/FM antenna is incorporated into the XM SAT antenna. I found part #28208-JJ50B and the cheapest I located was $217.42 (discountinfinitiparts.com). This is brand new from Infiniti.
HOWEVER,
I also found this one on eBay for $40:
G37 Convertible Antenna- eBay
and this one which is even better at $30:
G37/Q60 Convertible Antenna- eBay
Unless you find a aftermarket alternative, I, personally, would go with one of the used parts from eBay. Keep in mind that the base of the antenna can be swapped out with yours to keep the matching paint.
Hope thIs helps some.
Alex
mj_39
Picture Share G Sedan
22
Jun 14, 2013 03:31 AM
toastmaster
Aug 9, 2012 02:50 PM
mariosg37
Apr 26, 2011 10:23 PM
086mt
Apr 21, 2009 08:54 PM
ObsidianGT
Car Care & Detailing
Nov 11, 2008 02:59 PM
