2010 nav into the 2009 g37
Old Aug 17, 2018 | 07:17 PM
flipmode007's Avatar
flipmode007
Have anyone installed a 2010 navigation system into a 2009 ?
I wanted to install a 2010 nav system into my 2009 because I heard that the screen had better resolution and that was a fail lol. I install the screen and tried it to work nothing came up, not even the infiniti logo appeared on the screen? is it because I did not installed the radio box that came with it? the only problem is that the 2010 does not come with the little SD card that we have on the 2009.
tks in advance
Old Aug 18, 2018 | 04:40 AM
JayDeePee's Avatar
JayDeePee
It has been done. You will need to change out the whole head unit with the display and rewire some connectors. It is not plug and play. Search the forum and you will find a thread on someone swapping out the whole system. I think the back up camera also needed changing. The 2009 vs. 2010 display resolution are different. The headunit outputs a different signal.
zmann96
Aug 26, 2018 07:32 PM
mydreamcar_g37x
Oct 16, 2016 01:21 PM
maracazzz
The FX-Spot
Oct 13, 2015 02:54 PM
Jamg37ster
May 3, 2013 11:46 AM
TicketProof
Dec 26, 2008 07:22 PM
