Gas tank sensor question!
Old Jun 30, 2018 | 04:35 PM
Dan G37's Avatar
Dan G37
Exclamation Gas tank sensor question!
So my gas gauge has been reading wrong for quite sometime so earlier this week I decided to clean out the sensor with Q tips. Seems that my gas gauge was working and it would go down to the E line.
So as my warning light goes off for low gas, I go and gas up and it filled up 18.5 gallons of gas! I stopped it myself because I was worried something went wrong and it wouldn't stop automatically. Has anyone else filled up 18.5 gallons or more? Also my gas gauge line is higher then the Full sign now.
Old Jun 30, 2018 | 04:43 PM
stealthee's Avatar
stealthee
It appears it has a 20 gallon tank so depending on how empty it is is should take every bit of 18.5 gallons or more.
Old Jun 30, 2018 | 08:25 PM
slartibartfast's Avatar
slartibartfast
Don't panic until you go over 19 gallons. Then you'll realize just how close you were to tunning out of gas.
I regularly go a needle width past E, even then I'm only putting in a bit over 18 gallons.
Old Jul 1, 2018 | 11:17 AM
stealthee's Avatar
stealthee
Psh. Back when I was DDing my Stealth I once put 20.3 gallons in it and it has a 19.8 gallon tank.
Old Jul 1, 2018 | 11:41 AM
slartibartfast
Did you report that filling station to the Feds for bilking customers? They have jurisdiction in that arena.
Old Jul 1, 2018 | 03:05 PM
Surfnazi's Avatar
Surfnazi
The gas fill tube will hold gas as well
Old Jul 1, 2018 | 03:56 PM
stealthee's Avatar
stealthee
This. I was beyond empty. Basically running on fumes. I knew I was low and the car actually jerked like it was going to shut off 1/4 mile before I pulled into the gas station.
Old Jul 1, 2018 | 08:33 PM
slartibartfast
I'm fairly certain the fill tube does not hold half-a-gallon.
Old Jul 1, 2018 | 10:51 PM
user 3587587's Avatar
user 3587587
yeah there is no way you filled more than what would it in the tank, that station is definitely screwy
Old Jul 2, 2018 | 04:11 PM
Dan G37's Avatar
Dan G37
I was not even below E, I was maybe 1/4th line. So I'm guessing my sensor is off.
I was expecting only 15 gallons or so and once it filled up to 18.5 I let it off thinking I must have messed something up when placing the sensor back in.
shumby
General Tech Questions
13
Nov 25, 2010 05:11 AM
adam
Apr 10, 2009 01:54 AM
joeposter
Sep 19, 2007 09:41 PM
