DS door open alert and fast left signal blink
Old May 27, 2018 | 08:23 AM
fromGtoZ's Avatar
fromGtoZ
Question DS door open alert and fast left signal blink
Hey guys, I'm having a wierd issue. My driver side door alert will not go off, and my right signal blinks really fast. I think all this was caused from the passenger side sunroof drain leak. I did check the signal lights, the bulbs are not blown.
after some research here, I was able to fix the leak in the drain. I assumed the BCM got water on it and was causing the malfunction. After a week of letting everything dry out, I checked the BCM's connections, and they where all dry as well.
I do think all the electrical problems are related to the leak, just don't know where else to check for the short. any ideas? The interior seems completly dry. I also removed the battery cover and checked in there, under the battery was kinda damp, but not water soaked. Nothing else looked wet in that area.
Old May 27, 2018 | 10:07 PM
Surfnazi's Avatar
Surfnazi
Did you check the door switch that's in the door well it has a rubber accordion around it
Old May 29, 2018 | 01:03 PM
fromGtoZ's Avatar
fromGtoZ
Looks to be ok. The rubber around it is good, not cracked or torn and everything was dry. Couldn't get the screw out to check the connection. Can't see why that would all of a sudden fail?
Old Jun 6, 2018 | 03:58 PM
fromGtoZ's Avatar
fromGtoZ
BCM malfuntion confirmed. Dealer just quoted $1085 to replace it.
I found the same part number on eBay for $60-$80, and gladly will pay to have it reprogramed...but dealer said they won't touch it.
Are there any other options?
Old Jun 8, 2018 | 10:46 PM
takemorepills's Avatar
takemorepills
Why does a used BCM need to be programmed?
Old Jun 9, 2018 | 06:47 PM
Surfnazi's Avatar
Surfnazi
Bcm is coded to your car after its replaced.
Zori_V36
12
May 29, 2018 06:33 PM
blue-sun
Jan 23, 2018 04:52 PM
Degenerazn
General Tech Questions
Oct 10, 2007 08:50 PM
