Brake Light Problems, strange
'10 37s coupe, I know this sounds crazy, in fact I have never seen this before. Under hard acceleration my brake light comes on. When I get it into the higher rpm's it comes on every time. Goes off in between shifts then back on when hitting around 4,000 rpm. It's so strange. No funny sounds or anything with it. Also occasionally the tcs light will come on in the same rpm range and stay on until turning the car off and turning it back on. If I drive it normal it is just fine. Any help with a starting point would be great.
Did you ever check your brake fluid level?
After you check your brake fluid remove all four wheels and check the thickness of your brake pads.
Might be a good time for pad replacement?
Telcoman
Telcoman
Telcoman
Just went through it and only thing I can find is showing adjustment. I think your on to something about replacement. Think I'll get one on order and try that. Thank you for your help
Try to determine whether it is a missing battery or ground or a problem in the wiring harness prior to purchasing any parts.
Telcoman
Make sure the fluid is filled to the max. Same thing was happening to me. My fluid was above the minimum line so filled it to the max line and problem went away.
I've started noticing this same problem. The emergency brake light comes on under hard acceleration, or when trying to get traction on a slick surface. I'll get the brake fluids checked and see if the issue goes away.
You will need to brake pads soon. My fluid was low, so I checked my pads and they were getting really low. Changed the pads and all the lights went away. The lights come on when the fluid is low, but if you don't have a leak then most likely your pads are worn. Don't put fluid in without checking the pads, if you fill it with worn pads then later when you put new pads on you will have to siphon the fluid out.
hayblondie
Feb 26, 2023 12:01 PM
Andy Kim
Oct 2, 2017 07:18 AM
boardaddct
May 25, 2012 09:31 AM
