Sundown Audio to help bose system
Old Jun 8, 2018 | 03:05 PM
  #31
SkyG37's Avatar
SkyG37
Originally Posted by Surfnazi
You dont nder ti upgrade the alternator I would change the OEM acid cell battery for an Optima red top. Wicked cas makes custom molded boxes that fit in the right rear corner of the trunk for a single sub. Even 1 10w3 is enough and you still have 95 percent of your trunk in a coupe.
Im actually in a sedan (not sure the difference in size for the trunk) but I was going to run a single 12 or single 15 maybe. I was just going to go the cheap route and maybe buy a kicker CVR but then again, I'm not sure. Of course, I know the difference between the quality brands (SA, DC, etc) compared to the low brand (Kickers, etc) .
I just need to read up on the wiring. I was going to have a shop do it but I would love to save money but idk if I have the time . Are you guys running an extra HU deck or using the OEM interface with a bass **** / equalizer .
Old Jun 8, 2018 | 04:24 PM
  #32
Surfnazi's Avatar
Surfnazi
OEM with jl controller
Old Jun 9, 2018 | 11:33 AM
  #33
F13SC's Avatar
F13SC
If your only adding a sub I would tell you to use an Audio Control LC2i, if your running more than 2 amps with cross-over then LC7i
Both should be wired before oem amp.
I'm still running on all Bose, just added to it
Old Jun 19, 2018 | 12:27 PM
  #34
F13SC's Avatar
F13SC
For those that don't know what the car looks like
F13SC
Feb 12, 2018 11:43 PM
brianstamour
Sep 15, 2017 09:00 PM
m3clubracer
Aug 31, 2015 01:59 PM
BMWkilla
Aug 25, 2008 01:57 PM
