cruise control light doesnt come on
Old 11-01-2017, 03:03 PM
saywat?
saywat?'s Avatar
ive replaced steering wheel control (thinking the on/off button is defective) and ascd switch (not fun). i have a 6mt. what else could it be? is there a fuse associated with cruise control that is not labeled cruise control? any insight? brake switch (brakes lights work fine)?
thanks
Old 11-01-2017, 03:51 PM
slartibartfast
slartibartfast's Avatar
You say cruise control light doesn't work. Does cruise control actually engage?
Old 11-01-2017, 03:55 PM
saywat?
saywat?'s Avatar
cruise control indicator does not turn on when i press the on/off button on the steering wheel control. nor does it engage when i try to set the speed just incase its just a indicator not working. and i do not have icc.
Old 11-01-2017, 09:43 PM
saywat?
saywat?'s Avatar
so i guess the brake pedal has a ascd switch too. ima try that one with the one i removed. they both share same part number
Old 07-10-2018, 09:42 PM
saywat?
saywat?'s Avatar
so this issue has finally been resolved. it appears 2 years ago the dealer replaced my ecm but installed the wrong ecm which was for icc. i just got this resolved and the dealer has been cool. so now my cruise works lol. so it turns out the wrong ecm can be installed and the car will show no signs of anything wrong lol
jpowersjr2 (07-13-2018)
Old 07-11-2018, 01:16 AM
slartibartfast
Gadzooks! Glad it was finally resolved and dealer did you right.
Old 02-15-2019, 10:23 AM
photopro
photopro's Avatar
i dont know if i buy that answer from the dealer; there is a switch under the dash next to the brake light switch. If the brake light switch goes the car wont start and you get all types of lights; VDC off, etc. I bet all they did was replace the cruise control switch, and charged Infiniti for an ECM!!
Old 02-15-2019, 01:38 PM
saywat?
saywat?'s Avatar
no the ecm conclusion was my conclusion. i told them and had them verify that they had indeed installed the wrong ecm. via previous work order. i replaced all the switches (both clutch and brake) already before hand with new oem parts. and bc the ecm for my car cant be purchased anymore from infiniti i provided my own ecm i got from ebay and in return they hooked me up with a new dash installed. it was pretty awesome.
