Amplifier replacement
I have a 2009 G37 Convertible..... The Amp in my trunk recently went out, and needs to be replaced. However the specific AMP for my vehicle (28060-JJ50A) is impossible to find used and is priced at $800+ on most websites.
I was wondering if anyone knows if I can use the AMP for the 2009 G37 Coup (28061-JK61A) as this is around $150 and easy to find.
Ultimately, I want to fix my audio system in the most cost effective way as I plan on selling the vehicle early next year. So I am open to other suggestions if they are reasonable.
Currently my entire Audio system are stock parts.
Thanks!
Thanks!
I'm with you on trying to save money but...
Is there any way you can compare the pins and harnesses?
I don't know of anyone who has swapped out the two different amps
Thanks!
Thanks!
