Engine bay 12v switched access
Old Sep 10, 2016 | 10:05 AM
jcleejr's Avatar
jcleejr
Newbie to forum! I recently became owner of 2012 G37 Coupe. Installing LED DRLs and having difficulty finding 12v switched power source. Haven't been able to find an easy way to get through firewall to fuse panel, so I am looking for a source in engine bay. The IPDM is extremely hard to remove so I was hoping to be able to tap a wire in the engine bay, but don't know which one is best.
Any advice appreciated!
Old Sep 15, 2016 | 09:36 PM
saywat?'s Avatar
saywat?
download the fsm and look at the ipmd diagram
Old Sep 15, 2016 | 09:58 PM
jcleejr's Avatar
jcleejr
Thanks
Thanks saywat?
Old Sep 16, 2016 | 10:40 AM
TBau651's Avatar
TBau651
I would run it into the cabin, Its pretty easy to run a wire through the firewall, this way you can also add a kill switch inside the cabin. If you go with a fuse/wire in the engine bay, grab a multimeter and poke around with the car off and on until you find a wire or fuse that behaves the way you ware wanting it too.
Jedclampet
Feb 9, 2017 12:31 PM
Lothar52
Sep 25, 2016 02:02 PM
zmancb7
General Tech Questions
Sep 9, 2016 11:36 PM
ace3058
Sep 9, 2016 04:44 AM
Datsun40
ECU Tuning / Dyno Data
12
Sep 6, 2016 08:31 PM
