Aftermarket Heads Up Display (HUD)
Old Sep 6, 2016 | 06:54 PM
muadib69's Avatar
muadib69
Installed this aftermarket HUD. It plugs into your OBD port and turns on/off automatically. It displays your MPH, water temp, voltage and RPM. It automatically adjusts its brightness for daytime and night. It comes with a reflective film so you can see the image better but I opted not to use it. I can see the image just fine most of time except for direct sunlight.
Old Sep 6, 2016 | 08:15 PM
sharkey's Avatar
sharkey
pretty cool, does it just sit on top of the dash?
Old Sep 7, 2016 | 02:23 AM
muadib69's Avatar
muadib69
Yes it just sits on top of the dash and reflects back on windshield. I secured it with 3m double-sided tape. The image above looks blurry but the HUD is pretty clear.
Old Sep 7, 2016 | 06:15 AM
Crazyirish's Avatar
Crazyirish
Which HUD is it?
Old Sep 7, 2016 | 07:00 AM
Autocutter's Avatar
Autocutter
How does it look like during the day? How did you handle the wires? Does it require a separate power hookup or does it get it's power from the odbII connection? Anyway, looks cool!
Old Sep 7, 2016 | 07:22 AM
kiseliok's Avatar
kiseliok
G37 Community Team
Cool indeed, although I'm not sure how useful it is.
I always thought of a basic hud to be somewhat of a gimmick. These things have been around since late 80s and there is probably a good reason not many people cared about it.
The new ones with navigation and media information are sweet as you don't need to look at the main display to the right, but if it's just speed / temps it's sort of pointless - all that information is already right in front of you.
Old Sep 7, 2016 | 08:03 AM
Crazyirish's Avatar
Crazyirish
I had a '93 240sx with the factory HUD. It only displayed speed, but I really loved it. I find it much easier to quickly read whilst driving than a typical sweeping speedometer. My eyes arent that great though (contacts with pretty serious correction) so it may just be it takes me longer to refocus than some people.
I like the HUD in the OP, most of the aftermarket ones tend to be too large amd have way to much going on.
Old Sep 7, 2016 | 10:30 AM
muadib69's Avatar
muadib69
Originally Posted by Crazyirish
Which HUD is it?
This is the one I got from Amazon. There are tons of them all made in China of course. I tried to pick one that wasn't to colorful. I might get the more expensive one though because it has a built in flip up screen that reflects on it instead of your windshield. See attached pics.
Attached Thumbnails Aftermarket Heads Up Display (HUD)-hud1.jpg   Aftermarket Heads Up Display (HUD)-hud2.jpg
Old Sep 7, 2016 | 10:37 AM
muadib69's Avatar
muadib69
Its pretty bright even during the day. But once you get direct sunlight on your windshield its hard to see. I might get the flip up screen for it so that it will be clearer. There is 1 wire that hooks up to your OBD port (provides power). The wire is flat so you can hide it better. I rand it under the A-pillar and also below the windshield. The wires are not visible this way.
Old Sep 7, 2016 | 03:59 PM
Autocutter's Avatar
Autocutter
Looks awesome, had a HUD in my 2005 corvette and it was handy to keep me from speeding:-) mostly!
Old Sep 14, 2016 | 12:05 AM
bigc's Avatar
bigc
how quickly does the tachometer display your RPM? any latency?
Old Sep 14, 2016 | 12:50 AM
muadib69's Avatar
muadib69
Yes there will be naturally a delay as the info goes thru the obd cable to the HUD unit. However, you can adjust the offset of the unit's RPM and MPH to closely match your actual. The speed on mine is spot on and the RPM is very close to the actuals.
steven92
Jun 30, 2016 08:33 AM
ILM-NC G37S
Jun 23, 2016 10:49 AM
CharlesTheTruth
Jun 15, 2016 01:58 PM
nyhockeyplaya22
Jun 14, 2016 05:11 PM
bikezilla
Jun 10, 2016 09:00 PM
