automatic shift knobs
Old Jun 28, 2016 | 10:31 AM
steven92's Avatar
steven92
automatic shift *****
What automatic shift ***** will interchangeably fit with our G37's? Example, will shift ***** from a Q50, Q70, M45 etc fit?
Old Jun 28, 2016 | 11:16 AM
j50ny's Avatar
j50ny
The M35/45, M37 and Q70 will fit with slight modding to the shifter "shaft". Not hard at all. The Q50 may fit with no modification needed. The GT-R **** will also fit, btw
Old Jun 28, 2016 | 12:50 PM
Many will fit like j50ny mentioned, including the latest Maxima shift *****, but getting the trim ring to look proper can be a hurdle on most of them. Seems like the M ***** would be your easiest fit.
Old Jun 28, 2016 | 01:21 PM
j50ny's Avatar
j50ny
The new Maxima ***** are beauties
I also read somewhere that although a pita, you can take the trim ring from the M/Q70 and swap it over
Old Jun 28, 2016 | 02:04 PM
m3clubracer's Avatar
m3clubracer
I made an M45 fit by cutting two grooves in the metal sleeve and this allows one to go back to the OE ****.
Old Jun 28, 2016 | 02:17 PM
Mkhlmnn's Avatar
Mkhlmnn
Since I have had 4 I can give you my input ha. They all slide on without modifying. The M35/45 is the easiest. The 16 Maxima does fit the trim ring but the key is you need to reverse the directions as the front fits on the back of the **** and vice versa, then it clips together. The GTR **** fits also but trim rings will not work so you will have to attack the boot to the bottom painted collar of the ****.
The majority of these (minus M37/56 since thats the only one I can not speak on) will need the one or both of the shifter stalks shortened and slits lengthened.
However you can run these without any issue without modification and it works perfect, the only thing is the shift **** will come off if you pull it directly up, but I ran it like this with an M45 **** for months and have zero issues and it never moved unless I wanted it too.
Old Jun 30, 2016 | 03:27 AM
mummy2's Avatar
mummy2
Do you have a pic of the GTR **** in your car? I have an IPL with the red interior and i want the 2016 GTR **** but i can't justify spending $265 for it.
Old Jun 30, 2016 | 08:33 AM
steven92's Avatar
steven92
Yeah $100+ for a shift **** is crazy lol
VQHAY
May 3, 2020 12:55 PM
Eljefemoreno96
Jun 24, 2016 04:27 PM
warpeacelove
Apr 14, 2016 04:20 PM
TVPostSound
Apr 7, 2016 11:52 AM
milky
Apr 3, 2016 07:42 AM
