Help Non Bose head unit removal
Old Jan 31, 2016 | 07:32 PM
m3clubracer's Avatar
m3clubracer
I am having a tough time getting to the back of the head unit in my '10 non bose wired car. I am trying to tap the wires coming from the head unit to install a sub amp but can't get it out. I am stopped by a black bracket at the bottom of the head unit that the fascia was screwed to and is preventing it from coming all the way out. How do you remove it? Is there a detailed write-up on removal? The best post I can come up with is:
https://www.myg37.com/forums/audio-v...audio-zed.html
The second and third pics have the Metra harnesses used but the radio out further than what I have been able to accomplish. Do you use the wires coming out of the back or the ones on the top that go to the controls fascia?
I have read the manual, looked on line, pics, videos, nothing. Please help?
Thanks in advance, frustrated?
Old Feb 1, 2016 | 09:00 AM
blazeplacid's Avatar
blazeplacid
As far as I remember....
You remove the radio buttons/face. Then the main unit should come out with 4-6 screws.
Can you move the radio at all or is it stuck in place? Sometimes there are black rubber guides that you must slide the radio out of
I'll take a look at lunch time.
Old Feb 1, 2016 | 09:25 AM
m3clubracer
Thanks. I am able to get it off the guide poles but the little black bracket that holds the small 90deg curved piece at the bottom above the coin door/power port (whateva that thing is) and the radio face is in the way. Maybe I will try it again but it appeared as if you had to remove it and it would not come out due to the large trim pieces that run about waist high from waist to knee.
Old Feb 22, 2016 | 08:26 AM
m3clubracer
I forced it out. NBD.
dalton91
Jan 30, 2016 05:50 PM
