Audio question
Audio question
I have a 2008 infiniti g37s factory sound system works fine but I installed an after market subs and amp was working fine but now my amplifier is giving me the red protect light I replaced the after market amp with a brand new after market amp and it is still putting my amp into protect what might the problem be the ground is good
The subs may be blown or you have a wiring issue. Two wires could be touching.
Disconnect the subs from the amp.
Then turn the amp on.
If the issue goes away, the subs or sub wiring is your issue.
If that doesn't work..
Remove the rca cables and then turn on the amp.
Try the remote wire also.
Audio question
johnadlertech
Sep 11, 2015 02:07 PM
