Will Bose system fit in non-Bose car
Old Aug 22, 2015 | 09:51 PM
m3clubracer's Avatar
m3clubracer
I have a '10 base and want to know if I purchase a Bose system amp, sub, speakers, will they fit, and is a base car wired for sub. I do not see a faq or sticky on the subject. Please help and tia.
Old Aug 22, 2015 | 11:51 PM
JakeG37's Avatar
JakeG37
I would not upgrade to the Bose w/Navi setup. If you want better sound, get a new head unit, component speakers for the front, and a nice sub in the trunk. As those of us who have the Bose w/Navi setup know, it limits us in our aftermarket options. It is nearly impossible to replace the head unit since it integrates so many essential functions. Although some add another head unit by doing some other modifications to accomplish their goal.
Old Aug 23, 2015 | 01:17 AM
Epiphany's Avatar
Epiphany
+1. Going aftermarket will get you way better results than the Bose system in our cars which is a fairly average system.
Old Aug 23, 2015 | 11:46 AM
m3clubracer
Used is cheap. Better than base OE. Do any of you know if it will plug and play?
Old Aug 23, 2015 | 11:48 AM
Kb Cool's Avatar
Kb Cool
Could he just tap the audio signal of the original head unit and feed it into a multi channel amp that could power aftermarket speakers and sub?
Old Aug 23, 2015 | 11:56 AM
m3clubracer
Sad thing is that there isn't any write up on good systems. I am spoiled by the BMW forums. And a bit lazy when it come to electronics.
Old Aug 24, 2015 | 08:45 AM
blazeplacid's Avatar
blazeplacid
I don't think this is true
I have a write up on my Nexus 7 and Bit ten D install. I have also posted the entire wiring diagram for the car. I have a post about drilling through the molex to run new speaker wire.
Another user has a Rockford 360.3 and a Zed amp with a sub mounted on the rear deck.
There is a huge post about installing a Nexus 7 in the dash with all the needed parts.
As far as head unit swapping goes, there is only one option from Metra and it's very ugly.
The only difference I notice in sound quality from Base audio to Bose was a little bit of bass. Tweeters sounded about the same.
I think you should look into a sub instead of swapping out for bose
Old Aug 24, 2015 | 09:00 AM
m3clubracer
I searched for Nexus 7 and your name never came up as a thread starter. Can you send me the link to these. I almost tried this in my TL but sold it. I was very interested in using it but need to know more about what I am loosing/gaining.
I was only going to be the front subs and maybe rears. The sub I was going to get an aftermarket and amp but, as before, I'm lazy. I went that route in my 540 and PITA! Do you know if the base cars have the wiring for Bose sub?
Thanks!
Old Aug 27, 2015 | 10:51 PM
m3clubracer
Anyone, Bueler?
Old Aug 28, 2015 | 09:45 AM
blazeplacid
The base model audio does not have the wiring for the bose sub
You might run into an issue with the impedance of the bose speakers also.
The bose speakers are usually 2 ohm or even 1 ohm.
The base audio set up is designed for 4 ohm speakers.
I'm not sure if the factory radio can run a 2 ohm load.
Old Aug 28, 2015 | 01:01 PM
m3clubracer
Well this is what I needed to know. Thanks! Does anyone know what ohms the base system has? I know the Bose is 2 ohm.
Old Aug 28, 2015 | 01:58 PM
blazeplacid
The base audio mids are 4 ohm clarion speakers.
Not sure on the tweeter brand but they are 4 ohm also
Old Aug 28, 2015 | 02:13 PM
m3clubracer
I'm not electrically inclined at all. Can the base system handle the 10" 2ohm Bose speakers with some kind of capacitor or something between speaker and the head unit?
Old Aug 29, 2015 | 12:46 AM
socketz67's Avatar
socketz67
Community Builder
Anything is possible given enough time and money.
While the Bose is decent factory setup, I'm not sure it would be worth the time and money to retrofit a non-Bose car with a Bose Studio on Wheels setup. My advice would be to take advantage of the simplicity of your current setup and upgrade using aftermarket components.
You could add a nice amp off the high level inputs with separate mids and tweets up front and maybe a powered sub in the back and this would sound quite a bit better than the factory Bose setup. Maybe leave the rear factory speakers for fill?
Old Aug 29, 2015 | 07:45 AM
m3clubracer
Unfortunately this is my only option. Just wish there was another 10" door option. Is there a 6x9?
