Window / Power locks not working
Old Jun 18, 2015 | 10:26 AM
kevinmward's Avatar
kevinmward
Angry Window / Power locks not working
Ok so randomly on the driver console only controls driver side window up and down and power mirrors for both sides.
it does not control windows on any of the other 3 windows. also does not control the locks. none of the other door consoles control windows/locks.
I know it isn't the motor in locks and windows because Sporadically it will work normally.
Also if i use the key fob i can lock and unlock door or if i hold down the button the windows will all roll down but then not go back up until it decides to work again. lol has anyone ever run into this type of problem?
PLEASE help before i light a match and burn this car lol banghead:
Old Jun 18, 2015 | 11:53 AM
Flakman's Avatar
Flakman
So window and lock controls work okay from the other door panels? Also, just for giggles, when you use the fob to roll down the windows, can you use the key in the driver's door to roll them back up? Just trying to get further troubleshooting information. Also, the FSM might shed some light as well
http://www.nicoclub.com/archives/inf...e-manuals.html
Old Jun 18, 2015 | 12:31 PM
kevinmward's Avatar
kevinmward
Infiniti G35 / G37 Factory Service Manuals - NICOclub
well as of yesterday i could wind the windows down with the other door controls but today nothing works only one that works is the driver side control to lower and raise window.
, key fob wont lower or raise any windows
Old Jun 18, 2015 | 12:43 PM
Flakman's Avatar
Flakman
Hmmm...that sounds like it might be the window lockout switch is engaged and/or having a problem.
Someone correct me if I'm wrong, but I thought the other door controls were in series from the driver's door.
Also, in Infiniti's infinite wisdom, they only let you lower the windows with the fob. You have to insert the actual key in to the driver's door and turn to lock and hold to roll them up.
Old Jun 18, 2015 | 01:04 PM
kevinmward's Avatar
kevinmward
i was thinking the window lockout was faulty as well but the door locks dont work either only way to unlock or lock door is with key fob.
and update
now the drivers window is acting up i had to let it sit for 20 min just to wind up my window lol..
if the drivers master switch thing is going bad will it cause other switches not to work?
Also cant wind down windows with fob or up with the key
Old Jun 18, 2015 | 01:26 PM
Flakman's Avatar
Flakman
Check out the FSM link. There may be something there to point to a controller or something like that that could be the culprit.
Old Jun 20, 2015 | 11:38 PM
13_SkylineSedan's Avatar
13_SkylineSedan
Have you ever had the driver's door panel off? I would look at the connectors beneath that control panel on your armrest to make sure they're properly seated. Without looking it up, I seem to remember all power for the window circuits passes through that little panel. There may even be a tiny black box located there.
What year and model?
Old Jul 9, 2015 | 03:23 PM
kevinmward's Avatar
kevinmward
12 37xs sedan
I just orderd a new driver master switch hopefully thats the culprit if not then guess ill be pulling all that other stuff apart
Old Jul 10, 2015 | 12:43 AM
13_SkylineSedan
That may do it. If you want to study up check right here:
Index of /FSM/G37/Sedan/2012
DLK.pdf is for your locks
PWC.pdf is power windows
etc...
Old Jul 10, 2015 | 11:09 AM
kevinmward's Avatar
kevinmward
etc...
Just wanted to say thanks so far i installed it this morning as has been working since ,
I guess its true looks liek they do work in series with master switch. i dont wanna jinx myself so far but if anyone wants a switch
or has same problem as me
http://www.ebay.com/itm/371356001406?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
got it there for 80 with lifetime warranty
Old Jul 14, 2015 | 11:23 AM
mrperfect229's Avatar
mrperfect229
I am having the exact same problem on my 08 coupe. The master switch will control everything perfectly, but will not roll down or up the passenger side window. I took it to Infiniti and that's exactly what they told me. The master switch window lockout is malfunctioning. They tried to charge me 799 for a new switch, so I just went on eBay and ordered one. I'm waiting on it now.
Old Jul 16, 2015 | 02:01 PM
kevinmward's Avatar
kevinmward
put new switch in from ebay and works perfectly!
800 thats insane! lol
Old Jul 16, 2015 | 02:07 PM
mrperfect229
It really is insane! The switch cost 339 dollars at Infiniti, there is no way labor is 460 dollars. It takes me less than 10 minutes to get the door panel off so I'm sure they can get it off much quicker than that. I love my car, but the Infiniti dealership is just a rip off.
Old Jul 17, 2015 | 10:43 AM
kevinmward's Avatar
kevinmward
you dont even have to take the door panel off lol,
just pop up that piece that surrounds the switch with a Flathead and that's it , literally a 3 minute job.
Old Jul 17, 2015 | 11:59 AM
mrperfect229
With that being said, yes, it is completely a rip off!
