Lol thanks to this thread, I'm about to buy a new switch and try to resolve the same exact issue with my car. Hopefully it's just the switch. Any special things I should know about before I order? It's a 2011 G37S with memory seats.
happened to me a couple months ago this is what I got https://m.ebay.com/itm/For-Infiniti-G35-G37-G25-Q40-Front-Left-Master-Power-Window-Switch-25401-JK42E-/292106130089?txnId=1543981096019
worked like a charm
worked like a charm
How is the quality and feel of buttons compared to OEM? Worth the $70 in savings?
About to order this part for my car. I have a 2011 G37 Journey Sedan. I’m having the same exact Kevin Ward described in his post years ago so I was going to order the same part he did but it looks like the page is no longer available or the item isn’t available anymore. Any update or suggestions? This is the link he posted:
you dont even have to take the door panel off lol,
just pop up that piece that surrounds the switch with a Flathead and that's it , literally a 3 minute job.
Does this work on the coupe as well? I'm having a hard time removing the plastic trim piece that the switches are held in on my 2012 coupe.
Any advice please?
I can only give my experience (2008 Coupe).
The interior door card (panel) must be removed in order to remove the window switch. There is one (1) screw that attaches the bezel to the door card which prevents the whole thing from "popping up" like you can do on the sedan. For reference:
Once you remove the door card you can easily pop the switch unit out of the trim bezel. You do not have to remove the trim bezel.
I removed the plastic trim by own but still locks are not working, suggest me what should i do? Either go with locksmith nj near me or find another way to fix the door lock problem.
Hope this helps...
Hello again! When you say that we don't have to remove the trim bezel, you mean the top part right? Therefore, we would only need to pry the bottom white plastic piece out. Am I missing something?
The above pic was to illustrate that- on the Coupe's- the bezel is screwed to the door panel and can not be "popped up" like the sedans.
On the Coupe, to remove/replace the window switch, you must remove the door card (panel) and release the tabs securing the switch to the bezel. The bezel remains screwed to the door panel.
Out of the blue (on my way to Carmax to get a price) none of the windows would open. With the key they did roll down little by little not at once all the way down, but would no go back up.
I can lock it with the key NOT from remote. If I try to lock it from remote there is no noise. Only when unlock from remote I can hear a click.
After reading the comments here, I ordered the master window switch from Amazon and with a YouTube video on how to, I was able to open the armrest panel and replace the master power window. Unfortunately for me nothing changed.
It's a 2012 Infinity G37X Can anybody please suggest anything? Carmax said that sunroof doesn't open either, but i didn't have the courage to try. At this point i have plastic bags taped all over the windows to protect it from rain. I can not deal with one more opening (in case sunroof will open and not close).
