HOW TO: Charge & Control all iPhones/iPods with your Infiniti 30-pin connector
Old Jun 8, 2015 | 11:24 AM
WhiteKnight37S's Avatar
WhiteKnight37S
I've owned my G37S for about 2 weeks now and ever since I bought it I've been trying to get my iPhone 6 to both charge & interface with the dated 30-pin Infiniti connector found on the older G37's. THE SOLUTION - you have to use adapters to change the charge pin over so it supports the new Apple devices.
Adapters you need to make this work:
Infiniti 30-Pin interface cable
Link Link
12V USB Charger
Link Link
Micro USB cable
Link Link
CableJive Charge Converter
Link Link
Scosche home dock charging adapter
Link Link
Apple 30-pin to Lightning adapter
Link Link
Lightning extension cable (optional)
Link Link
You MUST buy both charging adapters to be able to make this work. using just one doesn't work (yes, I've tried it). The micro USB plugs into the side of the CableJive adapter. Make sure they are constructed in the order you see in the video (scosche MUST be on top of the cablejive). It's also essential that you buy a REAL 30-pin ADAPTER FROM APPLE. 3rd party adapters will not work. I recommend buying an extension cable as well. The adapters all stacked on top of eachother are a bit of an eyesore.
Old Mar 5, 2016 | 01:54 PM
BTM23's Avatar
BTM23
Hey there, sorry to bump an older thread, but this is EXACTLY what I've been needing for my 2009 G37s! Can you confirm that this solution is still working for you? I'm about to order all of the items you suggested and I just want to make sure I'm not missing anything.
If anyone else has tried this, please let me know if it worked for you too?
Thanks!
Old Mar 9, 2016 | 01:36 AM
WhiteKnight37S
Thanks!
Yes! I have still been using this solution and it has been working since I first posted this thread, It's exactly what you need for a setup that will both charge and control your phone
Old Mar 9, 2016 | 01:01 PM
w3lmatatan's Avatar
w3lmatatan
Hi, I just got a 2009 G37x coupe, and I wanted to control my 6 Plus. If I could live without the charging stuff, can I use JUST the official lightning to 30 pin adapter and have it work? And also, if I buy a scoche passport charge adapter, will it achieve the same thing? If I can use the least amount of components to make this work, I will.
Old Mar 11, 2016 | 01:45 AM
WhiteKnight37S
If you use just the 30 pin adapter it will work (no charge). The scosche will only work when paired with the cable jive dock adapter. Using just the scosche and the 30 pin will not charge your phone
Old Mar 30, 2016 | 01:49 PM
BroteinShake's Avatar
BroteinShake
Micro?
what is the point of the micro usb cable
Old Mar 30, 2016 | 02:52 PM
WhiteKnight37S
The Micro USB provides the charging capability for your phone. Since the Infiniti connector uses a different charging pin designed for older style iPods, it's impossible to pull power from the factory plug. You have to use the micro USB hooked from a usb charger to the cable jive to supply power to your phone.
Old Apr 12, 2016 | 02:05 PM
mr_luv's Avatar
mr_luv
Wow there is no way to charge without so many different components just to charge? Or a way to clean up the method?
Old Apr 12, 2016 | 03:45 PM
WhiteKnight37S
Unfortunately not. I actually abandoned the 30 pin adapter and went for the bluetooth setup a few months later. This device is awesome, it allows you to use all the menu functions in the car (such as selecting playlists, artists, etc) as if your iPhone was plugged in. You still MUST use all the adapters in the thread before to make it work, but it will automatically connect to your phone and start playing music within the 30 seconds you start your car, every time!
Tune2Air Tune2Air
Lt8Che
91
Apr 8, 2022 04:55 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
Amrit.bhathal
Car Care & Detailing
Dec 29, 2015 12:20 PM
andrewk523
Nov 11, 2015 05:49 PM
Amrit.bhathal
Sep 1, 2015 07:03 PM
