Custom Grounding Kit
Old Mar 31, 2015 | 05:02 PM
Flakman's Avatar
Flakman
So I decided to make my own grounding kit. Instead of stringing the wires serially, I decided to make some custom aluminum grounding blocks. Since I have a Stillen cold air intake, I thought I would make use of the empty bracket space in the fender where the stock airboxes were. Luckily, my work has a machine shop with a waterjet. I designed the blocks with AutoCAD and had them cut on the waterjet, then cleaned up and tapped for 1/4x20.
Here are the brackets. Bent at about the same angle as the airbox brackets. Cut from 1/8" aluminum. Through hole for the 10mm bolt (gonna probably end up using VMS fender washers) to the fender and 1/4x20 threads for the block.
Here are the grounding blocks. Made from 3/8" aluminum. The top has a clearance hole to mount to the bracket. The bottom 3 are 1/4x20 to mount the 8awg grounding cables. Passenger: 1x to the battery, 1x to the wheel well, 1x to the engine. Driver: 1x to the engine, 1x to the wheel well, 1x open (haven't decided what to use that for yet).
Here they are connected. The next step is to clean them up, hit them with a couple of coats of etching primer, 2 to 3 coats of black, and then a couple of coats of clear.
Will post more pics as it all comes together. Still waiting on the cable and connectors. Will update as it happens.
Old Mar 31, 2015 | 07:19 PM
Painting them completely defeats the intended purpose.
Old Mar 31, 2015 | 07:41 PM
Flakman's Avatar
Flakman
The threads will be unpainted...which I figured would be no different than bolting the grounding kit to the painted strut tower which most have done and with 3/8" stock there should be a decent amount of threaded area. I had thought about masking some of the area where the cables will connect to make for a better connection (no need to ensure ground between the block and the body since the block itself is the grounding point connecting to the battery) but have not yet figured out how I would want that to look.
Old Mar 31, 2015 | 08:19 PM
Roadrash666's Avatar
Roadrash666
Interesting concept. IMO those would look good if you wet sanded them down to about 1000 or 1500 grit and left them natural aluminum. Good luck with your project.
Old Mar 31, 2015 | 09:59 PM
Flakman's Avatar
Flakman
I hear you...and thought about it. But would still want to clear coat to protect. Weighing options.
Old Apr 1, 2015 | 01:40 AM
RA081224's Avatar
RA081224
I would not rely on the thread contact to provide adequate grounding; especially given an aluminum block and supposedly stainless steel bolt?? Face to face contact is the best method for reducing electrical impedance on connections.
Old Apr 1, 2015 | 02:22 AM
Flakman's Avatar
Flakman
I agree completely, especially since the stainless will be the lowest common denominator. I will need to go back to figuring out a good look for a partial paint.
Old Apr 1, 2015 | 06:55 PM
Flakman's Avatar
Flakman
Okay. I went from 400 to 600 and then a quick trip to the buffing station starting with blue bar then white. Looks like I won't need to buy paint.
Old Apr 1, 2015 | 09:02 PM
Roadrash666
That looks real nice, hit them with some Flitz polish and they should only need a light touch-up every 6 months or so.
Old Apr 1, 2015 | 10:23 PM
dalton91's Avatar
dalton91
Beautiful!!! Real nice... stay with this look!
Old Apr 2, 2015 | 12:23 AM
Flakman's Avatar
Flakman
Thanks. Gonna go over them more carefully with the 400 and 600 then polish them out. Will get some pics when done with that portion. Still waiting for cable and sundries to finish everything. Thanks for the input all.
Old Apr 2, 2015 | 07:06 PM
Flakman's Avatar
Flakman
I thought I was going over them more carefully. But doing so on my breaks isn't enough. Gonna take them home and take my time sanding. The polishing made all too clear the lack of sanding
Old Apr 2, 2015 | 10:28 PM
Roadrash666
The buffing wheel is your friend and your enemy. LOL! I think they look pretty damn good right now, those little imperfections won't show when they're under the hood. I'm the same way though, I'm ocd when it comes to shiny stuff. Use lots of water when you're sanding, and try putting your sandpaper on a flat surhace.(a piece of glass is perfect) Keep the pics coming!
Old Apr 6, 2015 | 07:16 PM
Flakman's Avatar
Flakman
This is about as good as I'm gonna get it with the buffing wheel here. I think it hasn't been used for quite some time. Even raking the wheel didn't help a lot. Looks better though. The scratches are gone and it can stand a little cleaning up. But its good to go.
Old Apr 6, 2015 | 07:31 PM
Roadrash666
Dude! You're more OCD than I am. Those look awesome If they work as well as they look, you're gold. Nice work bro.
