No sound
Old Nov 29, 2014 | 01:37 PM
rklen1's Avatar
rklen1
Question No sound
Everything in my system works except I have no sound. The sound started to cut out when the radio was on for awhile and then later on return. Now it is permanently off. Anyone else experience this and/or does anyone have an idea as to what might be going on? Thank you for any help. BobK
Old Nov 29, 2014 | 10:49 PM
CRiME's Avatar
CRiME
Bose system? This sounds like it could be an issue with the factory amp.
Old Nov 30, 2014 | 01:44 AM
RA081224's Avatar
RA081224
Well, heres the usual 20 questions
  1. Does the head unit turn on (lights, indicators, does it tune properly)
  2. If its a Bose system, the amps will receive a turn on signal from the head unit. Verify this signal is good
  3. If the amp turn on signal is good, make sure the connections to the Bose amp are seated fully
  4. Verify that there is no sound from all sources (FM, AM, Satellite, CD, iPod, voice navigation)
  5. Do you have a cell phone integrated into the audio system via bluetooth? If so, disconnect the phone and test again
The answers to these questions should steer you in the right direction
Old Nov 30, 2014 | 01:55 AM
AroundTheG37's Avatar
AroundTheG37
This happened in my old coupe from time to time. Screen and headunit would be on, just no sound at all. Dealer ended up replacing it under warranty.
Old Jan 30, 2022 | 11:35 AM
Arey10304's Avatar
Arey10304
Hi dude,
I know it's been years and years since you posted this but do ou remember how you fixed it? Thanks in advance!
Old Jan 31, 2022 | 05:37 PM
Arey10304's Avatar
Arey10304
Hello guys,
Did anyone ever figure out a solution for this? I have the same no sound coming from my radio issue. ​​​​​​ I found a post on another board linked below, where a guy says he fixed it by resetting it with an obd scanner. Can anyone verify if they did anything different? I dont want to buy a AMP when i suspct that it isn't the issue. Thanks in advance!
https://www.cargurus(dot)com/Cars/Di...42602_ds953220
Old Dec 21, 2022 | 08:51 AM
JavierV's Avatar
JavierV
Were you abel to fix ur issue?,
Originally Posted by Arey10304
Hi dude,
Im having the same issue. I already checked fuses and replaced the oem amp and still diesnt work
Old Aug 22, 2023 | 06:55 PM
LeonAr's Avatar
LeonAr
Fix??
Did you ever fix it im having same problem. Just changed the amp to another and fuses are good. Everything lights up no sound from aux or radio. Volume stays at where I had it last and doesn’t move.
Old Aug 22, 2023 | 07:20 PM
JavierV's Avatar
JavierV
yea some of the wires that connect to the amp were all cut by the old owner who was trying to install his sounds system. just spliced them together again and it started working again
MwcVicTxG37
Oct 1, 2024 05:30 PM
Bman427
Apr 14, 2020 12:41 PM
J_Smith-G37S
Apr 8, 2017 10:00 PM
Darth Kinetic
Feb 1, 2015 03:21 AM
KahnQuistador
Sep 29, 2008 11:21 AM
