Sub Install Question
Old Feb 16, 2014 | 05:05 AM
tadmac's Avatar
tadmac
I'm curious to see what everyone has done here that has added an amp and sub. I want to be able to have some more control over the audio (treble/highs) as well. Anyone here use the Bit Ten at all? I'm looking at the cheapest/easiest install without having to pay thousands for a custom job.
Old Feb 16, 2014 | 07:48 AM
socketz67's Avatar
socketz67
Community Builder
A self powered woofer like the Infinity Basslink sounds like a fit. There are dozens of other options in this space. Adding a separate Amp+Sub gets a bit more complicated as the Bose system is not setup to be modified.
Old Feb 16, 2014 | 09:28 AM
Darth Kinetic's Avatar
Darth Kinetic
And TONS of threads in here for you to read. Use the search for a well vetted topic
Old Feb 16, 2014 | 10:49 AM
tadmac's Avatar
tadmac
I have been searching.. I was asking more along the lines if anyone has used a bit ten vs a cheap way to get the signal to the amp.
Old Feb 16, 2014 | 01:25 PM
Darth Kinetic
Sure thing. I am picking up a used Infinity Bass Link today. I will follow the suggestions in the Sticky thread to tap into the line level at the rear amp.
Old Feb 16, 2014 | 03:03 PM
DHS803's Avatar
DHS803
I have a RF P300-10. I had the BassLink in my Honda Pilot before I got my G and I like the RF better. They are very reasonably priced at one of the main online retailers ($179.99). In hindsight I wish if have gotten the 12".
Old Feb 16, 2014 | 03:17 PM
KEG97's Avatar
KEG97
Ditto. Same exact sub and I'm very happy with it. PLENTY of ooph. The only reason IMO to go for the 12 is if it fits better against the rear parcel shelf.
I have an Infinity Basslink and it doesn't hold a candle to the true sub/amp combo. I wouldn't expect accurate bass from it if you place it in the trunk.
Old Feb 16, 2014 | 06:00 PM
blazeplacid's Avatar
blazeplacid
I have a bit ten D
if you have the budget and time ...dont even think twice
the bit ten cleans up the stock signal and allows you to adjust your eq for each channel and you can set up time alignment.
I install all my own audio. Let me know if you have any questions
Old Feb 16, 2014 | 07:20 PM
Darth Kinetic
With a bit ten did you keep stock speakers and add a sub too?
Old Feb 16, 2014 | 07:48 PM
pebkac's Avatar
pebkac
I just added a JL 10w6v3 and a 500/1v2 this weekend. I paired it with a audio control LC2i, and it sounds great with the Bose system. I added the bass **** with LC2i for control.
DO IT NOW>
Old Feb 16, 2014 | 08:05 PM
Darth Kinetic
Where did you tap in for your signal?
Old Feb 16, 2014 | 08:10 PM
Darth Kinetic
Does the bass **** adjust gain or increase the low end signal like an eq?
Darth Kinetic
DO IT NOW>
pics plz
Old Feb 16, 2014 | 09:53 PM
blazeplacid
no i ripped out as much of the stock system as possible
If you are going to run a bit ten or any other mid to high end processor, you are wasting your time if you run the stock set up.
Old Feb 16, 2014 | 09:54 PM
blazeplacid
if you search for posts i've made, I have the full system wiring from Infiniti for both bose and non bose set ups.
Its pretty easy to tap in once you have the wire colors and harness numbers
