Security/ remote start bypass install
Old Feb 1, 2014 | 08:27 AM
magnamagus's Avatar
magnamagus
I NEED HELP?: I AM INSTALLING VIPER SECURITY/REMOTE START AND DBALL2 BYPASS USING DATA TO DATA MODE ---- 2010 INFINITI G37 PUSH TO START
Alarm: VIPER 5706 -- SUPPORTS DATA TO DATA -- REMOTE START + Security
DBALL2 BYPASS INSTALL GUIDE:*http://www.xpresskit.com/VehicleCompatibility.aspx?p=null&year=2010&make=In finiti&model=G37%20%28Smart%20Key%29&ps=1&s=0&c=0
I NEED HELP? CAN YOU PLEASE VERIFY THE WIRE TO WIRE CONNECTIONS FROM THE STANDARD VIPER MAIN HARNESS & REMOTE START HARNESS TO THE VEHICLE THAT YOU USED IN YOUR DBALL INSTALL PLEASE...
1. Which wires from the. STANDARD VIPER Alarm/Remote start Harnesses (6 pin, 3 pin, 10 pin,) NeedED To be connected to the VEHICLE in DATA-TO-DATA MODE?
2. IN data to data mode, IF ANY, which WIRE TO WIRE connections will have to be made from the VIPER ALARM/REMOTE START TO THE VEHICLE in Data-to-data mode?
3. Of the connectors that need to be connected to the vehicle, which connectors require Relays or Diodes?
STANDARD VIPER ALARM HARNESS CONNECTORS INCLUDED WITH ALARM (6 pin, 3 pin, 10 pin)
MAIN HARNESS, 6 PIN CONNECTOR
--H1/1 Red (+)*12vDC Constant -----> Does this go to Ignition harness?? or Not?
--H1/2 Black (-)*chassis ground -----> Connect to vehicle factory bolt?? Or NOT?
--H1/3 Brown (+)*Siren -----> Connect to Siren - + and – to chassis
--H1/4 White/Brown*Parking light isolation wire –---> Not used - D2D
--H1/5 White*Parking light output – (+ or -) depending on jumper –---> NOT used - D2D
--H1/6 Orange (-)*500mA Ground w? armed output – starter kill circuit – uses relay –--> NOT USED
Door Lock, 3 PIN CONNECTOR*
--1 Blue (-) 500mA Unlock output -----> Data to data
--2 Empty
--3 Green (-) 500mA lock output ------> Data to daa
REMOTE START, 10 PIN HEAVY GAUGE*
---H3/1 Pink (+)*ignition 1 input/ouput --->
---H3/2 Red/White (+)*fused (30a) ignition 2 / Flex relay INPUT 87 ---->
---H3/3 Orange (+)*ACCESSORY output --------> ignition harness??
---H3/4 Violet (+)*STARTER OUTPUT (car side) [onboard relay – direct connect] -----> Brake Switch (+)
---H3/5 Green (+)*STARTER INPUT (key side) [onboard relay- direct connect] -----> ?
---H3/6 Red (+)*fused (30a) IGNITION 1 INPUT ---->
---H3/7 Pink/White (+)*IGNITION 2 / Flex relay OUTPUT ----> Where????
---H3/8 Pink/Black (+)*Flex relay INPUT 87a key side (if required) of Flex relay ---------> WHERE???
---H3/9 Red/Black (+)*fused (30a) ACCESSORY / starter input (POLARITY FEED FOR Accessory/starter input relay) ---------> 12v constant ignition harness??
---H3/10 --->*No connection ??
[H3/2 RED/WHITE, H3/6 RED, H3/9 RED/BLACK and H1/1 RED are connected to 12v constant]
G37xhibeet
Nov 15, 2016 09:29 AM
joeposter
Sep 8, 2015 04:36 PM
Ricio1991
Aug 23, 2015 10:44 AM
Morgan Thompson
Aug 19, 2015 04:44 PM
cparise
Aug 19, 2015 01:51 PM
