Remote starter installed!
Hi guys,
Need a little help. I'm trying to program my D-Ball with the Xkloader and I select all my options and then on page 6of6 it says to review the setting before flashing or hit back. I try to click the green flash button and nothing happens. Did anyone run into this?
Thanks
Thanks
Wow that has been the must frustrating hours of my life getting that box programmed!! Thanks for help guys, I tried two different computers, many restarts, different drivers with no luck. Though downloading chrome and IE Tab worked! Thanks again guys
I did read a few places that the flashing process could have issues with IE11 (maybe 10 as well). Glad you guys got it solved. I ran my XKLoader through a VM on my Mac - worked just fine minus the driver issues I had.
Yeah I was extremely confused when I got to 6 of 6 and could not do anything so I tried the standard flash option and the Flash button was clickable so I figured it was a browser problem.
So when you go to flash the xkloader, i am assuming from the above posts, that the xkloader does not need to be attached to the dball/car right? You just flash the xkloader, unplug it, then plug it into the dball?
Also, what kind of wire did you use to extend the BCM wires? Where did you guys get the wire from?
The XKLoader is simply an interface device for connecting your DBALL to your computer. The device itself is only used during the actual flashing process from the Xpresskit.com web-based flashing utility.
For flashing your DBALL:
[*] DBALL -> XKLoader -> PC
For car installation:
[*] DBALL -> T-harness
For extending my harness, I picked up the 3-pack (25' Red, 25' Green, 25' Black) STRANDED wire spools from Radioshack.
75-Ft. UL-Recognized Hookup Wire (22AWG) : Hookup Wiring | RadioShack.com
Most of us are using Xpresskit products (DBALL or DBALL2) for remote start features. Xpresskit offers a connector tapping harness that allows you to install with only having to tap 2 wires, and install 2 wires (versus 10+ wires).
Can anyone confirm if it was the 1st option : Automatic controlled door locks, or option 5: Door lock control on data, that they disabled when flashing the dball?
I got everything installed yesterday. I noticed when i get in the car after its started and press the brake - my window goes down and then up as if the door was opened - do you have this happen?
