Blendmount/Wiretap Install Question
Old May 11, 2013 | 04:58 PM
nbdiver's Avatar
nbdiver
Has anyone installed a blendmount with the rj11 wiretap on a 2011 G37 Sedan? I am trying to install but the leads on the wiretap are not fitting into the mirror molex plug? I've tried every which way but it appears the wiretap plug ends are too big to fit in with the existing wire. Has anyone else that installed a blendmount have this same issue? If so did you figure out a fix? Thanks in advance for any help!
Old May 11, 2013 | 05:31 PM
dmccombs's Avatar
dmccombs
I just did one of these a few weeks ago. The molex connectors in the recent G37 cars is very tight.
Hopefully you have the wire tap from Blendmount. It is a little easier than the one you get from Escort.
What I did is find a very small finishing nail. I pushed this into the molex to create a little more room. When I pulled the nail out, the wiretap, still needed a firm push (use needle nose pliers), but the wiretap prong fit then, and were held securely.
Old May 11, 2013 | 05:33 PM
nbdiver's Avatar
nbdiver
I did get it from blendmount direct. I'll give that a try and see if it works. I was thinking of forcing something in there but was afraid to break the plug or damage the wire at its connection point. If you've done it I'll give it a try. Thanks for the information.
Old May 11, 2013 | 05:49 PM
dmccombs's Avatar
dmccombs
Diver,
Just push the nail into a corner of the molex connector that you need to place a wiretap. That way the nail isnt damaging the wire that is already in the molex.
Old May 11, 2013 | 06:01 PM
nbdiver's Avatar
nbdiver
Diver,
I wonder if our plug is the same? Mine is so tight. Even putting a small finishing nail doesn't see like it would work but I am still gonna try. See picture. Also did you tap the gold or silver wire?
Attached Thumbnails Blendmount/Wiretap Install Question-20130511_133036.jpg
Old May 11, 2013 | 06:29 PM
nbdiver's Avatar
nbdiver
I just gave it a shot with the smallest nail I could find and as I expected I can barely get the nail into the plug. Its just too tight!
Old May 11, 2013 | 07:11 PM
dmccombs's Avatar
dmccombs
Diver,
I don't know how small your nail is, but mine was very tight too. You are using the nail to create more room in there, so it should be very tight. I used a finishing nail, like th small nails used for paneling or baseboards.
Old May 11, 2013 | 08:10 PM
nbdiver's Avatar
nbdiver
Diver,
Does my plug look just like yours?
Old May 11, 2013 | 08:38 PM
Rad_Slinger's Avatar
Rad_Slinger
I used a sewing needle with a pair of pliers to make room inside that plug.
As stated above, they are very tight. Ad ya....your plug is just like mine
Old May 11, 2013 | 10:33 PM
IPL 370GT's Avatar
IPL 370GT
I'm running the blendmount and mirror tap. Install was very easy... Zero issues. One of the pins was a snug fit. I did the install on a coupe however
Old May 11, 2013 | 11:15 PM
dmccombs's Avatar
dmccombs
Yes, thats it.
Old May 12, 2013 | 12:11 AM
Fezzik's Avatar
Fezzik
I made my own connectors, with phone cord, but I had to get a hammer and flatten the connectors a little more to get them to fit.
Old May 12, 2013 | 12:37 AM
1G372nv's Avatar
1G372nv
When I did mine I used a small flathead screwdriver. Like the one that comes in a glasses repair kit. It created enough space without any damage. GL
Old May 12, 2013 | 12:48 AM
nbdiver's Avatar
nbdiver
Thanks for all the feedback! I am going to give it a try again. Which colored wire did you all tap if your plug looks the same as mine?
Old May 12, 2013 | 05:59 AM
Rad_Slinger
I believe brow is the switched power, black is ground, and grey is steady power. I went off brown i think.
Been a while, can't remember.
