Speaker setup for 2011 sedan (Non Bose)
Old Dec 6, 2012 | 09:35 PM
Mr Lahey's Avatar
Mr Lahey
Hey all, new to the forums, just got a 2011 G sedan in liquid platinum.
It does not have the Bose audio, does anyone know the speaker sizes for each location? I'm kinda surprised how hard it is to find info for such a popular car, Crutchfield basically just told me there's nothing they can help me with and that's NEVER happened with any car I've owned before.
Thanks for any help.
Old Dec 6, 2012 | 10:51 PM
duffdaddy's Avatar
duffdaddy
Grats on the car.
I'm pretty sure you have a 10 inch hole in your front doors and then a spot for a 3" and 1". Replacing these with a 2 or 3 piece 6.5" component set is the way to go.
I'm not positive on the rest but unless you care about the sound quality of the rear seats then there is not really much point of replacing them.
What are your goals and spending limits?
Old Dec 9, 2012 | 02:51 AM
Djfarhan's Avatar
Djfarhan
happy modding!
Old Dec 11, 2012 | 12:35 PM
mystikal's Avatar
mystikal
congrats!!
check this guys thread
https://www.myg37.com/forums/audio-v...audio-zed.html
I copied him and installed a 10" in the rear deck...best idea
Old Dec 11, 2012 | 02:10 PM
blazeplacid's Avatar
blazeplacid
For the base model these speaker adapters will work
Custom Sub Enclosure | Affordable Sub Box
Im currently working on my door panels and these fit with no problem.
You keep the large plastic "housing" that the speaker is placed on.
here is what you will be looking at
Old Jun 22, 2020 | 09:51 PM
Chase Maples's Avatar
Chase Maples
Hey! Im working on my speakers for the front driver side, any advice on how to take the door carts off? i'm worried about pulling too hard and breaking something. Its especially "stuck" near the mirror. I have a 2011 Infiniti G37x
Old Jun 22, 2020 | 10:32 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Originally Posted by Chase Maples
...zis especially "stuck" near the mirror. I have a 2011 Infiniti G37x
You did remove the three (3) bolts? Two (2) behind the door grip and one (1) behind the interior door handle/lock assembly?
There is a large clip in the area of the mirror/tweeter. Once you release the clips along the bottom and front portion of the panel ("card") you should be able to reach up/in with your arm and pop it loose. It is just tension holding you up. If this is the first time the panel has been removed it will be especially tight (as most first times are ).
You do have to pull the door card hard- like you mean it. Just don't go gorilla on it as there is very little slack with the wiring harnesses.
Old Jun 22, 2020 | 10:48 PM
Chase Maples
Yeah, I removed the bolts. Looks like I just have to pull on it a little harder. Secondly, can i use any speaker thats 6 1/2 / 6/3/4? or should i use a bose speaker? I bought a 2012 bose speaker, hoping it will work.
Thanks for your response on such an old thread
Old Jun 23, 2020 | 07:47 AM
ILM-NC G37S
I've become a master at taking the door panel off after several mod projects over the years. You'll get there. Once you get your hand under and near the stubborn clip you can work it loose.
As for speakers, use what you have. If is just a straight swap you should be fine though I'm sure the speaker expert audiophiles- which I definitely am not- will have other opinions.
Good luck!
Old Jun 24, 2020 | 06:20 PM
Chase Maples
Good luck!
I just took the door cart and speaker off. I inspected the speaker and it doesn't look like anything is blown or torn in it. what could this mean? is it blown internally? should i get a new speaker or attempt to salvage it somehow?
Any way i can diagnose it?
BassAddictJ
Apr 13, 2022 04:11 PM
TRANKI_813
Feb 15, 2018 09:43 AM
Jonathan_92831
General Tech Questions
Nov 4, 2017 07:10 PM
biggigeez
Nov 16, 2011 06:59 PM
