1st Issue - USB is Dead/Bluetooth Streaming
So 1st issue, I've been effin pissed off with my USB drive just constantly having me to unplug and plug the USB drive back in order to read it so I went out and bought a new one. It has been doing the same thing and now it's just at 'Check your USB memory or iPod." So I ask you kind folks, am I doing something wrong?
Secondly, how do I get the Bluetooth streaming option to work?
I'll be picking up my plates during this week so I will have to have them address this then
@DaCePtak0n
- you didn't tell us if your issue is when using a thumb drive, iPod(type), iPhone(#) or all/other.
- if the problem is with the USB port, it will be fixed under warranty so don't worry about it.
Setting up a BT audio connection is very easy.
--- On your preferred device, enable BT and turn discoverable to 'on'
--- Press the cars Settings button followed by touching Bluetooth-> Connect Bluetooth -> No.
--- Type your chosen 4 digit PIN code (can be anything you want like 1234).
--- Your device should discover the car BT and prompt you to retype the PIN you just created.
BTW - it's all in the OM, (Pg 4-66 in my 2011 manual)
My bluetooth is connected to my phone but when I press SAT/AUX multiple times, it takes me to another Bluetooth capability to stream audio but it's not working. I have an iPhone 4 btw
As stated "USB drive just constantly having me to unplug and plug the USB"
BT phone connection is a different setup than BT audio streaming.
You can actually connect two different devices at the same time. For example you can connect your phone for making phone calls and connect an iPod Touch to the BT Audio streaming.
Just follow the instructions for connecting to BT Audio Streaming.
The USB issue ***could*** be caused by the file system format (check owner's manual, but FAT16 or FAT32 is probably best) or the format of the files. DRM on the audio files could also cause them not to play at all.
I also imagine that a large USB drive could present issues to a system as basic as the one in the G37. If you have anything bigger than a 4 GB USB drive, try the 4 GB drive or smaller and see if that gives you less trouble.
Another thing that could be causing the problem is heat. If your USB drive sits in your car on a hot day, it could degrade the USB drive's performance to the point of not working.
According to what I've read in other posts on this forum, bluetooth audio streaming with the G37 has never been smooth. I highly recommend a direct connection to the headset jack using the auxilary input. It's less convenient, but you'll save your battery and get slightly better audio quality.
-Brian
-Brian
-Brian
-Brian
When I BT stream from my BB or my kids' iPod touch, its smooth and the sound quality if good.
si_driver
Oct 1, 2015 09:53 AM
