2009 Infiniti g37 Iphone 4 Audio
Old Sep 3, 2012 | 07:06 AM
beleami's Avatar
beleami
Hello guys and thank you for reading this post. I have an 2009 G37 non-Nav and I want to be able to listen to my audio from Pandora/Spotify. Is there some sort of hack or anything I can do so I can stream the music via Bluetooth?
Old Sep 3, 2012 | 10:11 AM
rpm&my_G35's Avatar
rpm&my_G35
You can add something like Parrot MKi9100 Bluetooth Kit Install - G35Driver
The OEM bluetooth is not equipped with A2DP so there is not a 'built-in' solution or hack. The 2010+ models have A2DP.
Old Sep 3, 2012 | 08:27 PM
beleami's Avatar
beleami
I just basically want to hear my music through my car speakers. I just found out about FM transmitters... have you heard anything about it?
Old Sep 4, 2012 | 05:21 PM
BuckNorris's Avatar
BuckNorris
im not sure about the 09. does it have the usb port or just aux? i have an 11 and if i open pandora on my 4s and play the music BEFORE i plug the phone into the iPhone cord, it plays through the speakers as well as displays title/artist info. i can also use the 'skip' function on my steering wheel. music MUST be playing on the phone while connecting the cord. however, if i change the station, i have to unplug, press play on the new station and plug it back in. not sure about spotify. hope this works for you. update after you try it.
Old Sep 5, 2012 | 09:23 AM
rpm&my_G35's Avatar
rpm&my_G35
All 09's have Aux jacks in the armrest. The simplest solution, with excellent sound is one of these:
3.5mm Plug Jack to 3-RCA Male stereo audio cable 70CM | eBay
It requires control through the device and nothing appears on the car LCD screen. Steering wheel volume control will still obviously work.
FM Transmitters typically suck. Poor sound quality and the annoyance of finding new frequencies to use if you are travelling and the FM you usually use is suddenly picking up a radio station.
GW330
Feb 2, 2024 05:41 PM
e92ry
Dec 31, 2015 08:02 PM
joeposter
Sep 8, 2015 04:36 PM
cellwoot
Aug 13, 2015 04:27 PM
Ali K.
Aug 5, 2015 11:49 PM
