2009 Music Box Shuffle?
Old May 1, 2012 | 07:48 AM
Negotiator999's Avatar
Negotiator999
I just purchased a used g37x Coupe and am in the process of downloading the CD's to the Music Box. Does anyone know if there is a way for playback with SHUFFLE from one album to another, instead of having to play each album or artist at a time? It looks like no SHUFFLE option is available.
THANKS
Old May 1, 2012 | 08:02 AM
SwissCheeseHead's Avatar
SwissCheeseHead
There should be a "repeat/random button" in your radio cluster. There are several shuffling and repeating ooptions to choose from.
Old May 1, 2012 | 08:11 AM
Negotiator999
Thanks--I will have to readdress it. I didn't originally see a SHUFFLE option. I wanted to to be able to SHUFFLE between songs from different artists much like an ipod. THANKS
Old May 1, 2012 | 10:58 AM
SwissCheeseHead
No problem. Do you have nav or non-nav? If you have nav, I can take a picture of the button for you. I fyou have non-nav, it should be addressed in your owners manual.
Old May 1, 2012 | 11:05 AM
Rad_Slinger's Avatar
Rad_Slinger
I think the button is the same for all nav/non nav sets. I thought the buttons were different just in front of the LCD, but the ones above the climate control are the same.
Could be wrong.
Anyway, the button op is looking for should be right next to the volume ****. Says random/repeat or something like that. Just gotta have the cd juke up and just push that button until random is displayed on the screen....least that's how it is on my non nav.
Old May 1, 2012 | 12:31 PM
Tazicon's Avatar
Tazicon
I shuffle songs, so it shuffles through every song. I can also make it shuffle with in an album. I can not get it to shuffle albums though. Not saying it won't but I didn't ever put much effort into it.
The only issue I have with shuffle on the Bose system is you can't go back to the song preivious once its played. It also tends to switch to where it plays the songs in alphabetical order sometimes after the car is shut off. Then I have to switch it back (which if I remember correctly can only be done when you are not moving).
Old May 3, 2012 | 08:17 PM
Negotiator999
Thanks everyone. I do have a nav system I will see if I can find the shuffle option. I am glad that it sounds like that is an option!!! Thanks ALL!!
Old May 3, 2012 | 09:52 PM
SwissCheeseHead
Its the "SCAN/RPT" to the left if the clock. Press it a couple times until it says "Random All"
Old May 5, 2012 | 01:53 PM
Negotiator999
Thanks everyone VERY HELPFUL!!!
Old May 5, 2012 | 02:18 PM
Rad_Slinger
But did what we said here work?
Old May 5, 2012 | 02:40 PM
SwissCheeseHead
lolz. must've? I'm assuming that's what he was looking for.
Old May 6, 2012 | 12:21 AM
Negotiator999
Yep it worked great!! I was thinking it was on the navigation panel should have known it was the scan/repeat button. Again THANKS for the input!!
2K1 6T8
Oct 6, 2015 07:40 PM
G37sPhoton
Oct 4, 2015 11:08 PM
butwhatuptho
Oct 4, 2015 07:51 PM
djdiskino
Sep 29, 2015 07:18 PM
k19g37x
Sep 29, 2015 02:46 PM
