Help Blown Rear Speakers
Old Jul 20, 2011 | 12:21 PM
fluxemag's Avatar
fluxemag
Blown Rear Speakers
I have a JL 10W6 in the trunk in a custom box I made just below the rear parcel shelf. Unfortunately, I've blown the stock speakers out in the rear. I suspect the resonance of the sub popped them since the trunk is probably pretty air tight with the seat up. I have the non-bose system and a 2010 coupe. Any thoughts on how I can change up the factory speaker arrangement without spending too much dough ($600 or so)? I'd rather not install another amp, since the mono block amp takes up most of the mounting area on the seat back.
Would replacing the speakers alone be worth it, or would they just get blown for lack of power from the factory head unit? I was thinking some decent components for the doors and maybe just removing the rear speakers and leaving holes for the trunk to port through. Maybe it would be possible to bridge the front and rear channels to beef up the power output going to the doors.
Old Jul 20, 2011 | 03:52 PM
Brooklynstar23's Avatar
Brooklynstar23
I was under the impression after market speakers dont fit in our G's (except for the rear subs) You might be able to put after market speakers in but it will take quite a bit of modding.
Old Jul 20, 2011 | 04:15 PM
Why replace them? Rear speakers are useless. Have you ever gone to a concert and intentionally faced away from the stage so that the music comes from behind you? Are the main speakers in your stereo at home placed at the back if the room? Music should come from in front of you, not behind. Rear speakers = evil. Disconnect them altogether.
Old Jul 20, 2011 | 04:41 PM
fluxemag's Avatar
fluxemag
I'll give disconnecting them a shot, if the fronts aren't loud enough to keep up with the bass coming from the trunk I guess I'll have to see what a stereo shop can do for me on the doors.
Old Jul 20, 2011 | 07:32 PM
Fully sound deaden the front doors. Disconnect the rear speakers. Replace the front speakers with a quality set of 2 or 3 way components. Buy a quality amplifier for them and run 75 to 150 watts of clean power to each side. You'll be happy.
Old Jul 21, 2011 | 04:45 PM
fluxemag's Avatar
fluxemag
Thumbs up
Update...the sub was blown, not the rear speakers. I put a new one in at lunch and all is well.
m3clubracer
Sep 13, 2015 09:01 AM
JakeG37
Aug 22, 2015 03:31 PM
JakeG37
Aug 12, 2015 08:49 PM
JakeG37
Aug 3, 2015 09:28 PM
