Auto door lock speed sensing answer. finally
Old Aug 8, 2011 | 07:23 PM
rpm&my_G35's Avatar
rpm&my_G35
Originally Posted by MACS
Figured it out. Car turned on, hold down the driver's side door lock button until the hazards flash.
Thanks.
OK, so this is easy. Just to be clear (in case anyone else is a little slow like I sometimes am) press ignition to "ON" but do not start the vehicle.
How did PDX get the following 2007+, AT Sedan features;
1. Lift Steering Wheel on Exit
2. Slide Driver Seat Back on Exit
to work on the 6MT sedan?
I had it on my 07 G35x premium non-nav (only used the lift steering wheel on exit feature) so I would like to have that on the 2011 6MT sedan too.
Old Sep 2, 2011 | 04:14 PM
bythabay's Avatar
bythabay
20 Year Member
Thanks.
let me make that a little more clear. Hold down the driver's side door lock button by pressing the "lock" (not the "unlock") part of the button. When you see the hazard lights flash once, you've disable the auto locking feature. If you see the lights flash twice, the feature has been enabled.
This was throwing me off earlier when I tried it...
Old Oct 5, 2011 | 12:54 AM
mikaly's Avatar
mikaly
Not OEM, you'd have to install a KP Technologies add on module to get it.
Too bad, I wish it was OEM on 2007s. I actually liked this feature when I got a G37 loaner from the dealership.
aktif8
May 23, 2016 11:56 AM
Dillybar12
Oct 14, 2015 02:08 PM
Badgerman
Aug 19, 2015 02:26 PM
Abramite
16
Aug 8, 2015 08:35 AM
