Smart Start on 2010 g37(Video)
Old Mar 7, 2011 | 10:06 PM
  #46
john6mt's Avatar
john6mt
Hey ModMe, my installer tried to do my friends 08 coupe today with Dball, for some reason its not working with factory remote or door buttons. Do you know if there is a difference between older G alarms and newer? He called Databus support and he said something along those lines. Any Ideas? Thanks!
Old Mar 7, 2011 | 10:12 PM
  #47
Modme's Avatar
Modme
He probably did something wrong. I have a 2008 G37 Coupe.
Old Mar 7, 2011 | 10:17 PM
  #48
Modme's Avatar
Modme
Which alarm system are you using with the dball? Did he connect them with d2d?
Old Mar 7, 2011 | 10:31 PM
  #49
symple84's Avatar
symple84
Originally Posted by maxfinity
Dont know what you mean by special edition but i recommend you get it from and have it installed by an installer listed on vipers website and make sure the installer is familiar with newer push start systems.
Hey max I am local in Miami, I am curious which shop did the install? Also, do you think it is still in the 1000 price range or now that they have done a few it should be more reasonable?
Old Mar 7, 2011 | 10:56 PM
  #50
A_Palaroan's Avatar
A_Palaroan
thats tight. too bad i have a 6mt
Old Mar 7, 2011 | 11:02 PM
  #51
Modme's Avatar
Modme
Doesnt matter. I installed it on my 6mt. Car will only start when the car is in a neutral gear.
Old Mar 7, 2011 | 11:08 PM
  #52
john6mt's Avatar
john6mt
Hes using the viper 5701 and yeah he used the D2D, hmmm strange..
Old Mar 7, 2011 | 11:13 PM
  #53
john6mt's Avatar
john6mt
how did you hook the two door look wires up?
Old Mar 7, 2011 | 11:15 PM
  #54
Modme's Avatar
Modme
Couple of other things that i can think of:
1) CAN cables connected correctly? If the car can remote start, then this is probably fine.
2) Firmware flashed to the correct one?
Old Mar 7, 2011 | 11:16 PM
  #55
Modme's Avatar
Modme
Currently I have the DBALL control the doorlocking and the OEM security is disabled. When I have time, I plan to go back and connect the door lock wires and re-enable the oem security.
Old Mar 8, 2011 | 12:12 AM
  #56
john6mt's Avatar
john6mt
thanks Modme, Hes gonna check it out again tomorrow.
Old Mar 9, 2011 | 02:16 AM
  #57
maxfinity's Avatar
maxfinity
I got the alarm done at:
Custom Kar Sounds of Miami Inc
700 NE 167th St, Miami, FL 33162-2461 <NOBR>(305) 945-0037</NOBR>
You could probably talk them down a bit, their prices seem to be negotiable. You could also buy the alarm else where and have them install. May come out cheaper.
Old Mar 9, 2011 | 06:02 PM
  #58
symple84's Avatar
symple84
The firmware is available online. But you need an USB to D2D interface module in order to copy the firmware to the DB-all. Amazon.com: Directed Electronics XKLOADER2 Upgraded XKLoader Compatible with CANMAX400: Electronics
If your installer is familiar with DBall, then he should already have this. If not, then you might have to flash the firmware for him.
Man they are charging like $600 just for the install!!!! I know a few of you guys have done it yourself or is it worth paying $600? Also, I am understanding correctly that the only thing needed to make everything work is the actual alarm system and the DB-ALL (flashed to Nissan software)??
Old Mar 9, 2011 | 09:29 PM
  #59
Modme's Avatar
Modme
You also need to add a relay and diodes in there, but those things are dirt cheap. You can add additional sensors to the module if you wanted to. Also if you want to control the car with your phone, thats an additional module.
In all, there are around 20 wires that needs to be connected. Working in a public parking lot, in non-ideal conditions, with inadequate tools, it took me about 3 hours to do the install.
Old Mar 10, 2011 | 02:58 AM
  #60
maxfinity's Avatar
maxfinity
I dont have the slightest clue on how to install an alarm so i was pretty much stuck with them since no one else that i trusted was willing to do the install. Most places were saying they can do the alarm but not the remote start.
