Imported Contacts From Phone Displayed Backwards?
Old Oct 13, 2010 | 07:09 AM
Darknight16's Avatar
Darknight16
Hi everyone,
I just recently bought a 2011 G37 and am enjoying it quite a bit but the one small nuance that's bothering me is that when I import my phone contacts to the car, it displays them last name first, and first name last.
It's a bit annoying when I have to use voice command to call someone to have to remember to say their last name first.
Is there any way I can fix this? I'm trying to import from an iPhone 4 and I've tried changing the settings on the phone on how the contacts are displayed and sorted with no luck. Is this just simply a fault with the car and I have to live with it or am I missing some setting or way of importing contacts?
Thanks in advance.
Old Oct 13, 2010 | 10:16 AM
MiniRX7's Avatar
MiniRX7
I do not think there is a fix for this. I am curious as well.
Its something as to the way the iPhone stores the numbers. The only other way to fix this is to change all your contacts to have LAST NAME = First name and FIRST NAME = Last name.
Then on your iphone, you can show display as LAST NAME first, and the system will also flip this to the correct direction.
Old Oct 19, 2010 | 04:50 PM
Almatti's Avatar
Almatti
I have the same problem with IPhone 4 and a 2010 G37X. I had the Bluetooth feature in my 2007 G35. Is there a way to get to the Phone Number you want F A S T ....instead of scrolling through all the "stuff". My new car has Navi, the old one did Not.
In an emergency: There should be something more direct. Is there a trick I'm missing? In fact, that's the thing I hate about the IPhone ( a company issue - I would have preferred a New Balckberry, much better busienss phone), there is no easy way to make a call?
Old Oct 19, 2010 | 06:18 PM
joonrhee's Avatar
joonrhee
I'm feeling the same annoyance with you guys here. Voice commanding by last name takes some getting used to. And to go through quite a few steps to actually make the call is also annoying...
Old Nov 1, 2010 | 12:29 PM
Stez38's Avatar
Stez38
No fix for this? Everyone just suffers?
Old May 21, 2011 | 07:08 PM
dsandri's Avatar
dsandri
i just posted teh same question for my iphone 4/2011 G37 sedan. I can't believe there is no simple solution. Infinity messed up here.
Old May 22, 2011 | 02:04 AM
RKT SHP's Avatar
RKT SHP
Maybe if enough people complain they will come out with a patch or something....lolol
Old May 24, 2011 | 07:29 PM
RKT SHP's Avatar
RKT SHP
no one has a solution or a recommendation on this
Old May 26, 2011 | 04:30 PM
_ant_'s Avatar
_ant_
i wish there was a solution for this. it really annoying.
Old May 26, 2011 | 04:35 PM
christian655321's Avatar
christian655321
yeah there is a solution, change all your contacts names and put thier full name in the last name field. then they will be in order.
Old May 27, 2011 | 11:53 AM
DustinEarnhardt's Avatar
DustinEarnhardt
I'm running Windows Mobile (don't tell me, I already know...) and I have the same problem. Looks like it may be a problem with Infiniti's implementation and not just the phones. I, for one, will not be redoing all my contacts names to fix the problem. What a hassle.
Old May 27, 2011 | 01:28 PM
da mayor's Avatar
da mayor
every phone is different.... my blackberry I'm able to display first name last.
some options are effected from your phone settings, not from the car itself. everyone goes to blame the vehicle first.
Old May 27, 2011 | 02:41 PM
_ant_'s Avatar
_ant_
^we've all toyed with the phone settings. THANKS for the input.
Old Nov 21, 2011 | 02:04 PM
wickedwyrm's Avatar
wickedwyrm
I'm also looking for a fix on this for my iPhone 4s. When I had windows mobile it would switch sometime last, first. Sometimes first last. Now with the iPhone it is always last,first.
Old Nov 28, 2011 | 03:06 PM
Igor911's Avatar
Igor911
HA! I've actually gotten so annoyed with this that I've written a custom program to convert the names into First Last. In order to do this, you will need to export your contacts to an Outlook VCF prior to running my utility.
