Help Reverse camera install
Old Sep 6, 2010 | 12:28 AM
ch8ong's Avatar
ch8ong
help
cannot find the Reverse camera wire.
my 08 370gt coupe
thanks
Old Sep 6, 2010 | 02:42 AM
Weiboy718's Avatar
Weiboy718
Originally Posted by ch8ong
help
my 08 370gt coupe
thanks
what are you trying to do? i assume you don't have nav so even if you locate the wire there's really no use since you'll need the head unit for everything to work.
Old Sep 6, 2010 | 06:18 AM
ch8ong's Avatar
ch8ong
I have no NAV unit.
Thanks!
Old Sep 9, 2010 | 03:44 PM
RemmyZero's Avatar
RemmyZero
if you're looking for power for the camera you can just take if off your reverse lights. if you need a 12V trigger for a relay (or you could also use it for the camera) i know that the 08 G35 12V reverse signal is at pin 105 of the middle lower harness behind your head unit if i recall. looking from the harness side (where the wires come out) this is the harness layout.
there are some (not alot) of pics in my thread on g35driver also...
Installed E Coastal Tech Backup Cam with PAC VCI-NIS2 - G35Driver
i hope this helps!
Chris Olson
Dec 29, 2025 07:59 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
derekjl
33
Sep 8, 2015 08:40 PM
jessebritches
Aug 20, 2015 12:40 AM
cparise
Aug 19, 2015 01:51 PM
