HELP! Hidden Dealer Menu "Factory Reset" option removed menus from my controler
Old 07-09-2010, 10:11 PM
  #31
soolman32
soolman32's Avatar
Interesting... I ll have to give that a try
Old 07-09-2010, 10:19 PM
  #32
sick6speed
sick6speed's Avatar
Other than driving w/rear cam on...what other adjustments/benefits are there?
Old 07-09-2010, 11:04 PM
  #33
yogregb
yogregb's Avatar
Do you know if it's possible to change some colors on the status screen for example??
Old 07-09-2010, 11:33 PM
  #34
Mike
Mike's Avatar
Be careful of what you do here. Do the wrong thing and your system will be FUBAR until the dealer can fix it.
Old 07-10-2010, 01:55 PM
  #35
indycase
indycase's Avatar
Originally Posted by BLKG37X
Someone showed me how to get to an additional list of settings, such as various diagnostics options, and a few fun toys. I didn't get a chance to play around for too long, but my favorite so far is to turn on the back up camera as I drive. It's very James Bond. Unfortunately you cannot listen to the radio while doing it.
The way to this is to park, have the radio off, press down and hold the Settings button while turning the Volume **** back and forth very very fast. And a different menu appears on the screen.
Which buttons do you press after it goes into the diagnostic screen? How does it revert back to normal?
Old 07-10-2010, 06:05 PM
  #36
BLKG37X
BLKG37X's Avatar
^ You press back a few times until it goes back
Old 07-11-2010, 10:04 AM
  #37
Ivoidwarranties
Ivoidwarranties's Avatar
Like what? What can you screw up?
Old 07-11-2010, 11:05 AM
  #38
hispeed-lowdrag
hispeed-lowdrag's Avatar
you can mess with the audio stuff and some other electrical things and I think if you don't know what you are doing it can put them in a mode that only the dealer can turn off
Old 07-11-2010, 06:06 PM
  #39
328HP
328HP's Avatar
Used it yesterday for the back up camera when driving, its only thing you can do thats "meaningful". Its pretty cool. The novelty wears off pretty quickly though but its worth fooling around with.
Old 07-11-2010, 09:38 PM
  #40
Mike
Mike's Avatar
Disable features, make things "go away" etc. The dealer is the only way to restore them. So far, everyone I know that "screwed it up" pretty much tells the dealer it disappeared on its own, and the dealer just fixes it under warranty, since it's not a common issue, and the symptoms are very obvious.
Old 07-11-2010, 09:44 PM
  #41
xixonmn
xixonmn's Avatar
proof or GTFO.
Old 07-11-2010, 10:55 PM
  #42
SM_Shadowman
SM_Shadowman's Avatar
Originally Posted by xixonmn
proof or GTFO.
Translation: We don't know what went wrong so we're just going to go ahead and blame the customer. But we'll take care of it anyway since we can't prove anything.
Ultimately I suppose that's way better than the alternative!
Old 07-12-2010, 05:36 AM
  #43
PeterUbers
PeterUbers's Avatar
Nice! I was perpetually pissed that my bluetooth caller voice was too low even when maxed out .. i can adjust it through this menu -- sweet.
Old 07-14-2010, 05:36 PM
  #44
GmOnEy1
GmOnEy1's Avatar
How do u get the rear camera to come on after gettin to that screen
Old 10-16-2010, 06:32 PM
  #45
robd714
robd714's Avatar
Is there a setting to make the xm bands go away. My trial ended and I don't care to renew it.
Quick Reply: HELP! Hidden Dealer Menu "Factory Reset" option removed menus from my controler
