Iphone 3GS paired, but 2 issues
Old Aug 27, 2009 | 04:23 PM
sino408's Avatar
sino408
I wonder if anyone else is having this issue with the Bluetooth paired with their iPhone.
1. Checking your voicemail will lead to a bug, in which the car thinks you are making a call when you are only trying to listen to the voicemail (which doesn't even play). This loop cannot be canceled unless you manually disable Bluetooth on the iPhone then reactivate it.
2. When you pick up an incoming call using the car, it'll pretend it's picking it up, then switch back to audio for about 2 seconds, then switch back to the actual call. I can only imagine that this can be annoying for my caller since it probably sounds like I picked up the phone but didn't respond until 5 seconds later.
Old Aug 27, 2009 | 04:25 PM
jarborn1's Avatar
jarborn1
3. When the hell will we be able to load our phonebook.
Old Aug 27, 2009 | 05:49 PM
JaySpeed's Avatar
JaySpeed
I had my nav replaced about 4 - 5 months ago. With my old nav and old 1gen iphone i could not listen to voicemails at all through the car. I tried everything. since i have had it replaced and i have the 3gs i can now listen to my voicemail through the stereo just fine with no problems.
I would have the dealer take a look at it and probably get it replaced.
later,
Old Sep 9, 2009 | 01:24 PM
hoysumbrian's Avatar
hoysumbrian
hey guys i just got my iphone 3gs and the bluetooth does not connect! any suggestions ?
Old Sep 9, 2009 | 02:35 PM
B L U E S L A T E's Avatar
B L U E S L A T E
I don't have any problem using my 32gb iphone 3gs with my G.
Except that I DO want some phonebook uploading capability. lol
Raleclair
Oct 8, 2015 02:06 PM
viper630
Sep 12, 2015 10:48 PM
rgonz
Sep 11, 2015 04:07 PM
footballmania32
Sep 4, 2015 02:17 PM
