Ipod (iphone 3g) cuts on randomly
Old Aug 3, 2009 | 06:08 PM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Over the past few weeks - every so often while I'm driving and listening to XM or whatever- my radio randomly switches on my ipod without me prompting it to do so. Has anyone else had this issue?
Old Aug 3, 2009 | 06:22 PM
MattsG37's Avatar
MattsG37
I have had the exact same problem for the last week or two myself. So annoying, every two seconds it will cut off and say not connected, then ill switch to another setting and then the ipod will come back on, what can we do about this?
Old Aug 3, 2009 | 11:30 PM
KAHBOOM's Avatar
KAHBOOM
I think that it may be the cable or connector weakening. I was able to duplicate the problem by wriggling the cable vigorously. I may look into acquiring a new cable to see if that address the problem.
Old Aug 6, 2009 | 07:37 PM
KAHBOOM's Avatar
KAHBOOM
I knw that ther ewas a TSB for this type of issue somewhere:
https://www.myg37.com/forums/tsb-tec...-bulletins-12/
I'm not sure if the two issues are related- my ipod will disconnect randomly just the same as it will cut on randomly. It's annoying. I am going to presen tthis TSB to the dealer and hope that it fixes the problem.
Old Aug 8, 2009 | 07:24 PM
Ryuken09's Avatar
Ryuken09
Check my old thread.
https://www.myg37.com/forums/audio-v...sport-wtf.html
I had the same issue. Towbin Infiniti here in Vegas was of no use. After going back and forth quite a few times I decided to take matters into my own hands and play around with different iPhones. Turns out my iPhone had problems.
Still don't know if it was because I dropped my iPhone... never had problems charging or connecting to the computer, but I needed a different iPhone. Now all's well. Hope that helps.
Old Aug 8, 2009 | 10:26 PM
KAHBOOM's Avatar
KAHBOOM
Thanks for the info Ryuken09. That's very helpful
Old Aug 12, 2009 | 11:50 AM
KAHBOOM's Avatar
KAHBOOM
Update: I reflashed my phone and the issue went away.
Old Aug 12, 2009 | 11:55 AM
WhosUrBuddiee's Avatar
WhosUrBuddiee
Congrats
Old Aug 13, 2009 | 01:15 PM
Ryuken09's Avatar
Ryuken09
Glad all you needed was a refresh, though if your phone was banged up like mine, a new phone would have been even sweeter :P
Old Oct 17, 2009 | 01:18 AM
KAHBOOM's Avatar
KAHBOOM
update two... problem persisted after a couple of days. I obtained a new cable from Infiniti. It's been a couple of months now without any issues.
Old Oct 17, 2009 | 01:30 AM
Boomer-Bob's Avatar
Boomer-Bob
I'd check to see if the phone "sleeps" after you turn off the ignition. If it stays up / on the menu, the battery will go dead in time. Then, when the battery gets a bit of a charge while driving, it will come back to life and your audio will play it, without selecting it. iPods not sleeping or shuting down is a common problem. Some do some don't I'm trying to find a solution via another thread.
.... If you have a newer, USB charged iPod or iPhone, I think all you'll need to do is add an adaptor to the factory cable to charge it.
dn2931
Sep 5, 2015 05:26 PM
defektion
Mar 31, 2014 03:23 AM
SzaboTX
Aug 9, 2012 02:41 PM
Bahoni
May 12, 2010 06:42 PM
dezicartel
Nov 29, 2007 05:20 AM
